Oil changes
Old Jan 2, 2009 | 11:45 AM
TAMPAGT07's Avatar
TAMPAGT07
Originally Posted by kpaulhus
^ Unless your lowered... lol I have to drive up on 2 2x4's just to get on the ramps.
Yeah, I got ya. To me it makes no sense to raise your car "if it is not needed." It only takes me about 10 mins to change it, and most of the time is spent waiting for the oil to drain. With most cars you need to lift the car due to the oil filter location, but not with the stangs.
Old Jan 2, 2009 | 11:53 AM
ckone0814's Avatar
ckone0814
Originally Posted by illin
Well...for starters...quit changing oil every 1000 miles!
Oh, I don't - I do it by time, every 6-8 months or so. Got it new a year ago and it has 1900 miles on it.
Thanks for the info.
Old Jan 2, 2009 | 11:57 AM
avengence's Avatar
avengence
I do mine every 5k miles with mobil1 and MC filter. Sucks though, the prices on mobil1 at walmart went up to 26 dollars for 5 qts.
Old Jan 2, 2009 | 12:07 PM
TAMPAGT07's Avatar
TAMPAGT07
Wow..And I thought I was over doing it, by doing it once a year, after 1000 miles.
Old Jan 2, 2009 | 12:14 PM
2007CalSpec's Avatar
2007CalSpec
Originally Posted by Riptide
5W-20 is fine, 6 quarts is correct. PP is a good oil from what I've read. In fact I'm switching to it on my next oil change. As for the K&N I wouldn't bother with it. The MC OEM filter is fine.
+1 on the K&N filter. I thought about getting a K&N until I read some reports/tests that K&N actually lets more dirt in your engine than a regular filter. I guess that's the trade off for better flow.
Old Jan 2, 2009 | 12:15 PM
illin's Avatar
illin
Oil does not age.
For cars driven infrequently...once a year is a good change interval.
Old Jan 2, 2009 | 12:24 PM
ckone0814's Avatar
ckone0814
Sounds like I am over doing it. I am still gonna do it soon to get synth in but then I'll leave it alone for a year.
Old Jan 2, 2009 | 12:30 PM
ckone0814's Avatar
ckone0814
Old Jan 2, 2009 | 12:37 PM
TAMPAGT07's Avatar
TAMPAGT07
I picked Jan 1st to change the oil because it's the easiest for me to remember. I use stickers to remind me on my daily driver and change it every 5,000 miles (synthetic).
Old Jan 2, 2009 | 12:38 PM
Norm Peterson's Avatar
Norm Peterson
Ford's semi-synthetic and filters for me.
If your driving generally falls into one or more of the "Special Operating Conditions" listed in your Scheduled Maintenance Guide, you should be changing the oil and filter at 5000 mile / 6 month / 200 engine hour intervals, not the 7500 interval. Only occasional "S.O.C" driving does not require following the S.O.C schedule.
Unfortunately for many of the folks here, the owner's documentation does not specifically indicate which schedule that frequent high-rpm operation should follow. But my thoughts are that oil and filters are cheap, engines aren't, and I'll probably settle into changing it on average a bit before 5000 miles are up.
My other cars get Valvoline oil in the appropriate grade.
Norm
