Oil changes
These oil threads always take a turn for brand preference...which is just silly.
There is no (as in zero) independent testing ever done that any brand of oil is superior to another (in the same class). In fact, just the contrary.
Only in the US do we place so much emphasis on branded oils...and only in private sales. Look to industries where oil is ACTUALLY important (as in life critical applications (aviation for instance)) and you will find them using bulk oil.
Run the oil type specified by the manufacturer. The manual clearly defines the requirements and change interval...and afterall, Ford DID design the motor. Not anyone on Bobistheoilguy, not here and certainly no scamsoil salesman.
Maybe the Platinum really is better stuff. But didn't Quaker State have to modify their own marketing approach a bit once they merged with Pennzoil?
It's not a matter of brand preference with me. What I found when I got to look inside following consistent use of Pennzoil was not something I liked.
Norm
Norm
I think wally's and sam's is just able to demand, "if you want your oil in our store you're going to sell it to us for lower cost". I may be very wrong but I can't believe a brand like Mobil for example, would risk their reputation packaging a lower quality product in this case.
https://mustangforums.com/forum/4-6l...l-changed.html
Avoid Pennzoil like the plague.
You want a good synth like Mobil1 Full
Synthetic thats loaded with the needed Zinc
for proper engine wear......
