Spark Plug TSB and Warranty
I have almost 47K on my car and have yet to do the spark plug TSB. I called two dealers and asked about the TSB and both told me that the only replace the spark plugs if the car needs the plugs to replaced; the car needs to produce problems caused by faulty spark plugs. Does this sound correct? I was under the impression that they (ford) replaced the spark plugs regardless of having problems or not.
that sounds about right
just park your car someplace close by the dealership and try to do it yourself
if you break a plug, you can then push it to the dealership and have them finish it off ! joking aside,
follow the TSB to the letter and you should be fine
Good luck !
Good luck !
Either that or, "an ounce of prevention is worth a pound of cure." The sooner you get these things out and back in properly (i.e. with anti-freeze), the better. Wait till 100,000 and you'll be paying thousands of dollars to take apart your heads. Not smart, and in this case, not great advice.
True, the plugs are good for 100k, but with all cars, you do have to periodically break them free and clean them up a bit.
If its a weekend driver that gets less than 10K a year on it, chances are there will be carbon buildup goin on in the cylinder head.
KingRando
Oct 2, 2015 08:06 AM
