Sequence--Tail Light Problems
Old Jan 7, 2009 | 12:21 PM
Jokeurmnd's Avatar
Jokeurmnd
157 I bought mine off of RPI. I am thinking about seeing if I so switch them around if I end up with the same problem.
Old Jan 7, 2009 | 02:12 PM
mdg's Avatar
mdg
Try the forced reset, turn on right blinker for 10 min. This is what WebElectric told me to do, may/may not work.
Old Jan 7, 2009 | 04:17 PM
rneely2111's Avatar
rneely2111
Well it doesn't work again. My sequentials are meter4it and I tried to see if the wires are loose and they are not. I really don't know how to unplug it since I didn't install it.
Old Jan 7, 2009 | 04:32 PM
mdg's Avatar
mdg
In a nutshell...
1. Remove the black panel inside your trunk (6 black pushpins)
2. Remove the 3 nuts holding the tailight housing
3. Disconnect the wiring harness
If you want to remove the complete harness...
4. Gently remove the grommet holding the wiring harness, and pull off the tailight assembly
5. Twist off each bulb connector (one by one) and remove the bulbs
6. Put bulbs in stock harness and reverse steps 4-1.
It's been a while, I think this covers it.
Old Jan 7, 2009 | 04:41 PM
rneely2111's Avatar
rneely2111
The pulling the bulbs out and putting them back in I have already done.
Old Jan 7, 2009 | 05:07 PM
mdg's Avatar
mdg
Have you disconnected the wiring harness? If so, I'm out of suggestions, good luck!
Old Jan 7, 2009 | 05:10 PM
rneely2111's Avatar
rneely2111
What exactly is the wiring harness?
Old Jan 7, 2009 | 05:53 PM
munger's Avatar
munger
I just got a set of CDC sequentials and one of the things they say to do if you get them out of sync. is to disconect the battery to reset them.
Old Jan 7, 2009 | 06:25 PM
Joolander's Avatar
Joolander
Lord High Protector
wow so this sucks
im having the exact opposite problem as you
on my driver side blinker, the brake, turn and hazard signals are working and sequencing normally
but for running lights only the interior light works on the drivers side
Old Jan 7, 2009 | 07:19 PM
rneely2111's Avatar
rneely2111
battery option didn't work
