Air Pressure Question
Old Jan 11, 2009 | 06:04 PM
Nuke's Avatar
Nuke
I never said to ride on what the door placard says. Read my post #6.
Old Jan 11, 2009 | 06:17 PM
pascal's Avatar
pascal
S197 Section Modder-ator
I read it...
I have nothing against your advices.
Old Jan 11, 2009 | 06:19 PM
redfireshaker06's Avatar
redfireshaker06
Sorry wasn't meant for you
Old Jan 11, 2009 | 07:29 PM
Norm Peterson's Avatar
Norm Peterson
Originally Posted by redfireshaker06
I have 20's also. And your telling me that you should run your tires on what the door says. Even though the side wall height and size are completely different than what came on it stock?
In this particular case, the OP really should start out with 32 psi. The 255/40-20 carries the same load index rating as the OE 235/50-18's (97). It's when the load index for your new tires differs from the load index for your OE tires that you start thinking about starting at different pressures.
BTW, once you start to deviate from the sticker pressure, there is no reason to keep all four tires at the same pressure. Or at the same pressure difference if your fronts and rears are spec'ed for different pressures.
Norm
Tivo304
Aug 28, 2023 12:19 PM
StalkerGT
Sep 25, 2015 02:41 PM
cbird1177711
Sep 2, 2015 08:51 PM
cbird1177711
Sep 2, 2015 04:12 PM
