Lowering w/ FRPP Springs
Old Jan 11, 2009 | 09:10 PM
mochrome's Avatar
mochrome
Question Lowering w/ FRPP Springs
Thinking about lowering my GT convertible and was checking out the FRPP springs. Can I install the springs, get a realignment and be good to go? Or will other changes be required?
Thanks for your help.
Old Jan 11, 2009 | 09:19 PM
kpaulhus's Avatar
kpaulhus
you can just do that....but it is reccomended that you get new aftermarket shocks and struts. Here is a look of how low its gonna sit.
Old Jan 11, 2009 | 09:52 PM
jlugo_70's Avatar
jlugo_70
i suggest you get the frrp shocks aswell, this is how mine looks with the frrp springs.
Old Jan 11, 2009 | 09:59 PM
jeffo's Avatar
jeffo
Default frp spring
Hi,
I have the springs on my car. If you want to budget the install make sure to mark your current struts on removal so as you can put them back in at the same exact angle. This will not totally prevent the realign, but it could minimize it.
If you keep your stock struts in they will obviously work, but they will die out quicker as they will be in a precompressed status.
Old Jan 11, 2009 | 10:05 PM
VistaGT's Avatar
VistaGT
How come ford doesn't have a adj panhard with their FRPP kit? Everyone else seems to think you need one with a drop.
Old Jan 12, 2009 | 04:15 AM
mds08's Avatar
mds08
I have the FRPP lowering kit. It comes with camber bolts. I have 18x10 with 285/45's and it is aligned perfect. There is some adjustment in the rear panhard. The kit works perfect and the ride is awesome. Change the struts out when you put on new springs because you will spend more in the long run by paying again for the install. Save the money and do it all at one time.
Old Jan 12, 2009 | 06:36 AM
5SPD07GT's Avatar
5SPD07GT
Official Site Sponsor
you can install the springs yourself, its a breeze and shouldnt take more than 2hrs. The rears take 15min, its that easy.
Old Jan 12, 2009 | 07:03 AM
Doogie65's Avatar
Doogie65
Keep in mind that on convertibles, the rears take a little longer as the chassis stiffners run below the rear axle and do not allow the axle to drop far enough to remove the stock springs. There are 2 different ways to approach... take the extra time to remove the chassis stiffner bolts (about 10 total) to allow the rear axle to drop far enough or pick up a cheap spring compressor and you can quickly compress the stocks enough to allow them to drop out.
I found the second method from a guy another forum after I already had installed mine
If you decide to do this yourself and have and questions about the rears, just drop me a PM.
fcarpio
Suspension
Nov 16, 2018 10:35 AM
baddog671
Jul 26, 2016 01:20 PM
robcy
Suspension
Oct 27, 2015 11:14 PM
Gene K
Oct 21, 2015 11:37 PM
ccdguy
Sep 19, 2015 05:20 PM
