Underhood Spring-Loaded Switch
Old Jan 12, 2009 | 11:21 AM
underbird10's Avatar
underbird10
Default Underhood Spring-Loaded Switch
Anyone know what the switch on the passenger side of the engine compartment does when you raise/lower the hood? It would appear to be an alarm for the PCM to let you know that your hood is unlatched, but I can't find any write-up stating the purpose.
I want to switch some underhood lighting by this switch if possible.
UB10
Old Jan 12, 2009 | 11:23 AM
underbird10
Double post. Please reply to this message.
UB10
Old Jan 12, 2009 | 11:30 AM
HaneyMotorsport.Com's Avatar
HaneyMotorsport.Com
Banned
It should be for the factory alarm.
Casey
Old Jan 12, 2009 | 11:32 AM
underbird10
Thanks Casey.
Do you know if it's just a simple on-off switch or does it have any logic attached.
Thanks,
UB10
Old Jan 12, 2009 | 12:42 PM
Nuke's Avatar
Nuke
Any pics? I don't recall a switch and I have the factory alarm. I'd go look but I'm at work and the Stang isn't my DD.
Old Jan 12, 2009 | 04:37 PM
aircare84's Avatar
aircare84
Here's an old pic of mine that shows it,it's the black 'button' next to the fuse box, it's mounted to a little bracket on the inner fender lip.
Old Jan 12, 2009 | 04:39 PM
fullboogie's Avatar
fullboogie
Hmmmm. And I thought that was for my aftermarket alarm. Wonder if that shows a "door ajar" if the hood is left open, like the trunk.
Old Jan 12, 2009 | 04:55 PM
underbird10
Yep,
That's the beast... I guess I'll have to do some probing with a multimeter to find out what it does.
The story is that I installed some underhood light fixtures from a '99 Stang on my hood struts a couple of years ago. These have a BB inside that turns on the light when you raise the hood. However, since I changed to the RK hood, I don't slam the hood down any longer. I lower it slowly and use the hood locks to secure it.
Well... needless to say, the BB's don't move if you just slowly lower the hood, and I've run my battery down to nothing twice in the last couple of weeks. Pain in the ***... and that's an understatement!
So, next best thing would be using that switch to provide a ground to my lights and turn them on and off. I don't want to f-up anything, so I'm curious what this switch actually does.
Still interested if anyone has an answer...
UB10
Old Jan 12, 2009 | 05:42 PM
2cokeman's Avatar
2cokeman
It is a simple hood alarm switch, on off thats all!
Old Jan 12, 2009 | 09:05 PM
underbird10
Thumbs up
Excellent. It'll serve my purposes nicely then.
UB10
jwog666
Dec 27, 2021 08:09 PM
lincolnshibuya
Jul 5, 2020 03:05 AM
PaulH2
20
Jan 31, 2016 09:48 AM
guitarman376
Sep 30, 2015 05:54 PM
Colin Ringle
Sep 15, 2015 09:27 PM
