A/C Problems.....Werid!
Old Jan 16, 2009 | 04:58 PM
boomer123's Avatar
boomer123
Default A/C Problems.....Werid!
So the last 2 mornings i go outside and start my car up (it's really cold out btw and my car stays outside). The A/C tuns on for a second, and i try to put on the defroster and heat, then i put the air on full power and all the A/C lights turn off and none of them work and the Air conditioning completely stops working. So i drove to school freezing my *** off in my car. Everything else on the dash worked from the air control ***** up!
Then when i get back into my car at lunch, the air worked fine, so i kinda let it go.
Then the SAME thing happened this morning, same sequence of things and everything and it worked fine at lunch....??
Im really confused and idk what it could be, it has never done this before
Has this ever happened to anyone else?
Old Jan 16, 2009 | 05:35 PM
302me's Avatar
302me
I have a similar issue, the heat works and the blower controls work, but I can't seem to get the heat/air to come out of the vents. Sorry I can't really help. Just thought I would let you know you're not the only one suffering through the cold brotha.
Old Jan 17, 2009 | 12:09 PM
157dB's Avatar
157dB
Cut & Paste Expert
THIS should explain all the 'Weird' activity.
Old Jan 17, 2009 | 12:13 PM
mygt500's Avatar
mygt500
Multi-Tasking Moderator!
What db said above! ^^^
Old Jan 17, 2009 | 12:18 PM
pascal's Avatar
pascal
S197 Section Modder-ator
Make sense.
The good old Manual, once again...
I have a problem with the "Werid" activity though.
Didn't see that in the manuel
Old Jan 17, 2009 | 12:28 PM
157dB's Avatar
157dB
Cut & Paste Expert
Originally Posted by pascal
Make sense.
Manuel moved back to messico last week.
He took my owners manual with him.
Old Jan 17, 2009 | 12:42 PM
pascal's Avatar
pascal
Damn Messicans!
vargas
Jun 17, 2017 12:17 PM
69Volunteer
Sep 30, 2015 10:39 AM
SteelerNation82
Sep 16, 2015 07:11 AM
mrmrultimate
Texas Regional Chapter
Sep 10, 2015 09:43 AM
HIS S-197
Aug 10, 2015 05:47 PM
