Lights
Old Jan 24, 2009 | 12:36 PM
rfeyjoo's Avatar
rfeyjoo
Default Lights
Can someone point me in the right direction on how to change our headlight bulbs?
I got a set of silverstar H13 and cant find anything that instructs me on how to change the stock bubs out. I would imagine its easy but just wantr to make sure
Old Jan 24, 2009 | 01:16 PM
bronxbomba63's Avatar
bronxbomba63
Yeah, it's really easy. Here's a link to a service manual: http://www.onlinefreeebooks.net/auto...anual-pdf.html
Old Jan 24, 2009 | 02:39 PM
rfeyjoo's Avatar
rfeyjoo
i have to remove the whole bumper just to change the Bulb?????
rfeyjoo's Avatar
rfeyjoo
I didnt get HIDs or anything i just got 2 silverstart bulbs that id like to put in.
Old Jan 24, 2009 | 02:44 PM
So_Cali's Avatar
So_Cali
Its very straight forward. Simply find where the bulb is, and it should have only one way of turning the socket to get the old bulb out.
Old Jan 24, 2009 | 03:04 PM
wolfie's Avatar
wolfie
Replacing headlamp bulbs. As per the owners manual page 53.
To remove the headlamp bulb:
1.Make sure headlamp switch is in the off position, then open the hood.
2.Disconnect the electrical connector from the bulb by depressing the retainer clip and pulling rearward.
3.Remove the bulb by rotating it counterclockwise and pulling it straight out.
4.Install the new bulb in reverse order.
Old Jan 24, 2009 | 04:25 PM
157dB's Avatar
157dB
Cut & Paste Expert
Not necessary 157db!
Old Jan 24, 2009 | 07:15 PM
owero01's Avatar
owero01
157db apologizes.....
Not funny. This a newbi who needed help.
Old Jan 24, 2009 | 07:20 PM
mygt500's Avatar
mygt500
Multi-Tasking Moderator!
Play nice guys!
Old Jan 24, 2009 | 08:14 PM
Art161's Avatar
Art161
Be absolutely sure you do not touch the new bulb with your bare fingers. The oil on your skin can cause the bulb to burn out within minutes. Latex gloves are good, as long as you are not allergic to latex. If you have gotten some oil or other substance on the new bulb, clean it with alcohol before installation.
jwog666
Dec 27, 2021 08:09 PM
4cylinderplus2
Oct 9, 2020 07:45 PM
lincolnshibuya
Dec 8, 2015 04:37 PM
Explosive
Oct 2, 2015 07:45 AM
ChampInSD
Oct 2, 2015 04:55 AM
