Gauge Issues
Old Feb 19, 2009 | 10:49 PM
Rallek's Avatar
Rallek
Default Gauge Issues
I have an 05 Mustang GT. It has MyColor, though I dont think that matters.
Recently the gas gauge stopped working. I have seen other people post about this, but I dont think my issue is the same. It started when I parked my car for 2 weeks. When I got back in it, the gas gauge was below E. All gauges sit to the minimum when the car is off, but the gas gauge is further down. It doesnt move when the car is started.
If anyone has had the same issue, please let me know.
I think that due to the heat in Florida, the glue that holds the needle on the pin has come un-glued. The reason I say this is a mechanical issue and not an electric issue is because the Tach is now doing it. The Tach still works, but maybe once a week it will read low, like it too has come un-glued and gravity is pulling it down.
If this is the case, Ill get some cool white-face gauges to put in there and re-glue all the needles. The Tach issue is random, the gas gauge issue is continueous. It never moves.
Again, if anyone has had the same issue, please let me know.
Old Feb 22, 2009 | 04:18 PM
Rallek's Avatar
Rallek
Update: I havent made any progress with this issue. I have reset the EMU via battery disconnect, and by flashing it back to stock calibration, with no avail.
Old Feb 25, 2009 | 10:29 AM
Rallek's Avatar
Rallek
Someone recomended to remove the rear seat and check the electrical connections on both sides of the tank, and possibly add some electrical grease.
Removal of the seat is easy, theres are 2 buttons under the front of the seat. Push em and lift up on the front. Remove the 2 big round cromits. I just disconnected and reconnected the plugs a few times, as I dont have any electrical grease. When I started the car... Ta-Daaa, the gas gauge moved. This process took me all of 5 mins. There is alot of dirt in between the tank and the frame, so Im guessing dirt is the issue Ford has been having with this.
But! My Gas Gauge and Tach still dont read correctly. Im pretty sure its a mechanical issue in the dash because my needles jump, kinda like a second hand on a ticking clock. So either the pin is not tight in the needle hole, or the needle is falling off. See! My car's so fast the needles cant hang on! Anyways, I'll be taking the dash apart at some point and puting a bit of glue on the needle shafts.
Old Feb 25, 2009 | 03:51 PM
str8wick3d's Avatar
str8wick3d
The problem is with your stepper motors in your instrument cluster. they are bad in 2005s if you look up mustang stepper motor on ebay you can order them from a guy, take your cluster out and replace the motors.. Had the same problem with mine. Not sure what "glue" your talking about though.. No Glue is needed.
Old Feb 26, 2009 | 08:24 AM
Rallek's Avatar
Rallek
Thanks, Ill check out the stepper motor deal. The glue idea came from thinking the needles werent on the pins all the way. I guess I would have eventually figured out it was the motors.
Old Mar 3, 2009 | 02:45 PM
Rallek's Avatar
Rallek
Update:
Stepper Motors! It has been suggested and confirmed that my issue was the stepper motors in the gauge cluster. They are apparently bad in some '05 cars. You can order these from Ford or get them on Ebay(that's where I found them). If you can solder, these can be purchased individually($8). It is suggested to replace them all. I found a service on Ebay that does this, you just have to ship off your gauge cluster($140). Usually takes a week.
mtgldr
Feb 3, 2024 09:00 PM
andrew1969
16
Jan 8, 2016 02:48 PM
SteelerNation82
Sep 16, 2015 07:11 AM
MusicCity615
Sep 12, 2015 07:05 AM
Pyrate Dave
Sep 10, 2015 07:30 PM
