anybody with experience installing the mutha thumpr cam
anybody with experience installing the ***** thumpr cam
I just recently purchased the comp cams stage 2 ***** thumpr cams for my car...im going to be doing the install myself and was wondering if anybody had any experience with the install of this cam since it does not come with installation instructions?? any help would be greatly appreciated...I have found a few links to cam installs but most seem to have valve spring installs as well which this cam does not...here is a link to one that I have found...
http://www.powerperformancenews.com/...stall-452.html
does this look like a pretty good write up for a basic install...just wondering if this cam was a little different being that some steps of this install I wont have to do because I wont be installing valve springs...also where can you find the specialized wedge tool needed to hold the timing chain in place???
Lance
Lance
that's a nice write up, in fact i looked at it
for tips before i did my cams. here are a few
additional resources for your project:
ford on-line manual
http://iihs.net/fsm/?dir=165&viewfile=Camshaft - LH.pdf
comp cams phaser limiter installation:
http://www.compcams.com/Technical/In.../COMP4-119.pdf
there's also a cam writeup floating around this
forum, somewhere...
ford on-line manual
forum, somewhere...
there's also a fellow on another forum that
sells these cheap....anthony something or
other....
http://www.fordspecialtools.com/
303-1175
other....
303-1175
other....
303-1175
other....
303-1175
thanks a lot man...just ordered it
