Why are Garrett Turbo systems so cheap?
Do you get what you pay for? Why are these systems cheaper than everyone else?
http://www.horsepowerfreaks.com/part.../Mustang/14846
gt500 pumps $700
injectors $200-$300
intercooler $200 2 inlets /1 outlet (ebay)
piping $100-$200 (ebay)
cold side couplers $50 - need a 4.25 to 3" adaptor for the TB
Dyno tune w/ tuner $700
air filters $30
Maf bung to be welded to piping $45
HPS MAF $200 (maf for boost, anything over 400hp)
Blow off valve $50 (ebay)
HTO plugs $100
with the turbos being mounted to the underside,you would want to fabricate a shield to keep dirt and water off them as much as possible. you would also want to find someone who can weld up the cold side for you, aluminum piping would be best, but not too many people have resources to weld aluminum, you would need to mark the pipes and take them to a fabrication/welding shop. usually $20 a joint to have welded.
thats a real nice start to a kit. to complete that tuner kit you still need:
gt500 pumps $700
injectors $200-$300
air filters $30
HTO plugs $100
gt500 pumps $700
injectors $200-$300
air filters $30
HTO plugs $100
These are intended for a top side mounting I believe.
i think your right, i think this may be the same kit,installed.minus all the cold side stuff.
http://www.mustangworld.com/ourpics/News/select4854.htm
If anybody is interested in turbos, feel free to let me know, my close friend is a Precision Turbo distributor. http://www.precisionturbo.net/ I'm sure you will need a built bottom end before upgrading the turbos.
bradleyb
Nov 27, 2015 07:50 PM
breaking
Oct 2, 2015 01:27 PM
AMAlexLazarus
AmericanMuscle.com
Oct 1, 2015 09:21 AM
