Old Oct 22, 2015, 04:09 PM
How-Tos on this Topic
Last edit by: IB Advertising
Browse all: Ford Mustang Exterior Guides
Print Wikipost
Any "How-To's" to remove rear bumper?
Old Mar 16, 2009 | 11:27 AM
nbd13's Avatar
nbd13
Default Any "How-To's" to remove rear bumper?
Hey guys,
I am upgrading my bumper from the GT bumper to the gt500 or actually the GT/CS appearance bumper, which is the same as the gt500.
Are there any step by step directions out there to remove the rear bumper and replace it?
Thanks,
Nick
Old Mar 16, 2009 | 11:51 AM
partsbill's Avatar
partsbill
1. Remove the 4 pin-type retainers and the luggage compartment trim panel.
2. Remove the 4 rear bumper cover-to-bumper cover bracket screws.
3. NOTE: GT vehicles are equipped with 3 pin-type retainers.
If equipped, remove the 3 rear bumper cover pin-type retainers.
4. From inside the luggage compartment, remove the 4 rear bumper cover nuts.
To install, tighten to 5 Nm (44 lb-in).
5. Disconnect the electrical connector from inside the luggage compartment and remove the rear bumper cover.
Feed the rear bumper electrical harness through the rear of the vehicle.
6. To install, reverse the removal procedure.
1 58403D24 Luggage compartment trim panel pin-type retainers (4 required)
2 63424A82 Luggage compartment trim panel
3 W706805 Rear bumper cover-to-bumper cover bracket screws (4 required)
4 13B519 Rear bumper cover pin-type retainers (3 required) (if equipped)
5 N621927 Rear bumper cover nuts (4 required)
6 17K835 Rear bumper cover
7 — Rear bumper cover electrical connector (part of 14489)
8 54403D24 Rear bumper isolator pin-type retainers (2 required)
9 17C884/17C885 Rear bumper isolators (RH/LH)
10 W708877 Rear bumper bolts (8 required [vehicles built before 12/2005], 6 required [vehicles built after 12/2005])
11 17775 Rear bumper
12 W611103 Rear bumper cover bracket bolts (12 required)
13 17E850 Rear bumper cover bracket
Old Mar 16, 2009 | 12:23 PM
AlloySixxer's Avatar
AlloySixxer
https://mustangforums.com/forum/s197...rs-w-pics.html
This is V6 to GT bumper but it's the same concept, I believe. Scroll down for rear bumper.
Old Mar 16, 2009 | 12:56 PM
nbd13's Avatar
nbd13
Thanks guys.
Nick
Ryan Fitzpatrick
Sep 14, 2015 02:21 AM
Dragonus18
Sep 9, 2015 01:21 AM
Doogie65
Sep 6, 2015 02:55 PM
cbird1177711
Sep 2, 2015 08:51 PM
