Normal RPMs ?
Old Mar 17, 2009 | 04:27 PM
gnrpatience's Avatar
gnrpatience
Default Normal RPMs ?
Hello!
So i finally cleaned my Throttle body and MAF Sensor, I used a different cleaner for each one, both from CRC, one for Throttle body and the other for the MAF.
Have three questions:
1.- I just cleaned the MAF sensor, meaning that the MAF has a metallic plate, thats what I just cleaned, should i clean the pins that attach to the MAF or im ok with just that metallic plate ?
2.- For the Throttle Body i didnt take it off, just took away the filter and look inside, used some spray and clean very carefull watching not to catch other things, then pressing the gas pedal opened and cleaned in the inside with less spray and i saw dirty coming from it, is that ok ?
3.- Which are the normal RPMs when IDLE for a stuck mustang, 2007 V8, Manual.
Thanks
CS2007
Jun 25, 2019 09:45 PM
lincolnshibuya
Dec 8, 2015 04:37 PM
breaking
Oct 2, 2015 01:27 PM
guitarman376
Sep 30, 2015 05:54 PM
lmurf60
Sep 24, 2015 10:07 PM
