Rought idle...
Old Mar 19, 2009 | 05:57 PM
NastyEvolution2006's Avatar
NastyEvolution2006
Default Rough idle...
After I had the alternator replace, the V6 started to idle rough while idling in park or in drive with the brakes applied.
Jumps up and down between about 400-700 RPM.
Any thoughts?
Old Mar 22, 2009 | 12:28 AM
NastyEvolution2006
Bump... Anyone?
Old Mar 22, 2009 | 01:02 AM
StickShifty's Avatar
StickShifty
is it just plain idling rough, rpm goes up and down, or a combo of both.
a good start would be to clean the TB with TB cleaner, and clean the MAF with MAF cleaner. see what that does.
Old Mar 22, 2009 | 05:23 AM
Smooth_J's Avatar
Smooth_J
+1
The PCM could be on relearn as well since you just had it replaced. Scan with the X-Cal2 and let us know. Also, whats the interval like between high and low idle?
Old Mar 22, 2009 | 11:50 AM
NastyEvolution2006
The RPM's just go up and down about every 20 seconds or so. Idles at 700 then drops to 400, then back up to 700.
Rinse, lather, repeat every 20 seconds or so...
Old Mar 22, 2009 | 12:37 PM
mxg30's Avatar
mxg30
Read your first post and seems odd this would be the result of an altenator change, though rule nothing out. I agree with the replies on cleaning the throttle body. I had a simular issue with hard starts & rough idle so after cleaning the Throttle body (take it off) my issue was resolved. The difference was huge. Word of caution: Be very careful cleaning the MAF as it is a very sensitive piece.
Old Mar 22, 2009 | 04:03 PM
siberian.mist's Avatar
siberian.mist
ever changed the fuel filter?
Old Mar 22, 2009 | 04:36 PM
NastyEvolution2006
Yeah, that was the first thing I did... That and some fuel treatment.
I'll clean the MAF & TB as most have suggested. Thanks folks!
06BamaGT
Feb 16, 2010 03:54 PM
HateWhatOwnsYou
Sep 1, 2009 06:56 PM
nitrotweaker
Aug 13, 2009 12:33 PM
gjs14
Apr 24, 2009 09:41 AM
hi_tek_rednek
Jan 16, 2009 09:54 AM
