spark knock?????
Old Apr 22, 2009 | 09:55 PM
gjs14's Avatar
gjs14
Default spark knock?????
What is spark knock? I need info to help out some one at my work, he has a black 05 GT mustang 5 speed with 54K miles and we where pulling up his steep *** drive way, I don’t think he was giving it enough gas, the car started sputtering and I think knocking (running rought) so he rolled back and turned the car off and then he just stared it back up and it was running ok so what do u all think? I have heard of spark knock but don’t know what it is or if it was spark knocking.
Thanks
Old Apr 23, 2009 | 10:18 AM
gjs14's Avatar
gjs14
anything?
Old Apr 23, 2009 | 10:35 AM
jwog666's Avatar
jwog666
spark knock it when the fuel is ignited too early on the compression stroke. usually cause by excessive cylinder temps due to too much timing, a lean condition, and too low octane fuel. but what you are describing sounds like the fuel pump tsb ford has for hesitation stumble after long cruise. running out of fuel can also cause spark knock.
description of tsb
Some 2005-2006 Mustangs may exhibit a hesitation on acceleration after a long cruise. After coming to a stop from a highway type cruise, some vehicles may experience a hesitation when the customer begins to accelerate. Air bubbles can form around the fuel pump during a long cruise and be ingested into the pump on acceleration causing a hesitation.
Old Apr 23, 2009 | 10:56 AM
Nuke's Avatar
Nuke
That doesn't quite sound symptomatic of the fuel pump TSB. My g/f had the TSB issue and it was a definite hesitation on acceleration, not a sputtering or shaking. It almost seems like it started when you began pulling up his "steep ***" driveway which makes me begin thinking either water in the tank or low fuel (not sure where the pick-up is in our tanks; front, rear or mid). If that's ONLY when that happens then I'd rule out the TSB.
Old Apr 23, 2009 | 11:34 AM
157dB's Avatar
157dB
Cut & Paste Expert
It poor low octain fuel being pre-ignited by a
hot spotand then the spark ignited the rest of
the fuel and the explosion wave fronts collide.
The result is a knocking sound. Very,very destructive.
Its caused from improper timing and/or low
octain fuel. The engine has a knock sensor
and logic in the PCM to adjust the timing
when knock occures. It usually happens
under a full load going up a hill at 3/4 to
full throttle.
I dont think you were hearing knocking.
He was lugging the engine and was not
giving it enough gas. Press the gas down
and dont baby it up the driveway.
Old Apr 23, 2009 | 12:21 PM
07 GT E UPP's Avatar
07 GT E UPP
[QUOTE=157db;6141750]It poor low octain fuel being pre-ignited by a
full throttle.
and dont baby it up the driveway.[/Q
+ 11111111
Now here's a guy who know's what he's talking about.!!!
Old Apr 23, 2009 | 03:06 PM
gjs14's Avatar
gjs14
Thanks for the help, I will let him know..........he had some one at ford look at it today and they did not think it was knocking at all and no check engine lights are on so I hope all is good, he has had allot of s@#t go to hell on his 05 mustang
Old Apr 24, 2009 | 09:41 AM
ski's Avatar
ski
What gear was he in when the problem happened?
Dathan
Oct 5, 2015 05:52 AM
jessicarabbit
Sep 25, 2015 12:41 PM
dalehunter
Sep 25, 2015 10:51 AM
2015Ecoboost
Sep 17, 2015 01:48 PM
Emblazoned
Sep 3, 2015 10:45 PM
