Awkward sputtering
Old Mar 21, 2009 | 09:39 PM
dschmink's Avatar
dschmink
Default Awkward sputtering
I took my stang for its first road trip today after the cam and dyno tune. After going 60-65 on cruise control for about an hour I hit a light. When I tried to drive from the light, as soon as I would engage the clutch the engine would sputter. Did this twice in a row and on the third it worked just fine. Happened on the same trip at another light 30 minutes later.
On the return trip, no such problems. Also, on a cold start first thing in the morning my car will shoot up to 2k rpms and do a "hard idle" I guess I would call it. Could the two be related and is it most likely just the dyno needs a small adjustment?
Old Mar 21, 2009 | 09:50 PM
jahudso2's Avatar
jahudso2
I know there is a TSB for the fuel pump acting up after cruising on the highway.
Old Mar 21, 2009 | 10:24 PM
Hootna's Avatar
Hootna
Mine was running like crap kind of surging not sure if it was a result of the cams etc. I installed. anyway decided to replace the fuel filter with a high flow unit and havent had the issue since.
Old Mar 21, 2009 | 10:25 PM
mygt500's Avatar
mygt500
Multi-Tasking Moderator!
its the TSB for the fuel pump as you do have an 05 GT......it is not the tune!
The tune on mine for a cold start will do this...jump to about 2K rpms and slowly come down to 1100-1200 rpms for about 30 seconds and then go to my idle which is set at 850-900 rpms shortly after that....this is totally normal on a cold start!
Old Mar 21, 2009 | 11:27 PM
dschmink's Avatar
dschmink
Alright, glad I'm not alone on the LOUD startup in the mornings haha.
As for the TSB, how much would that run to fix and what is all involved?
*nvm found prices and labors per the TSB. Thanks
Last edited by dschmink; Mar 22, 2009 at 12:03 AM. Reason: Google solves everything
Old Mar 22, 2009 | 07:01 AM
mygt500's Avatar
mygt500
glad you answered it but if your in warranty they should cover everything.....
Old Mar 22, 2009 | 09:46 AM
dschmink's Avatar
dschmink
I've been out of warranty for a while now.
ShaneB26154
35
Mar 4, 2021 04:05 AM
MEISTERSNFB
Mar 31, 2020 07:50 AM
freefallin98
Nov 17, 2005 09:08 PM
Lucidus
Aug 25, 2005 10:18 AM
phils04gt
Feb 28, 2005 02:33 AM
