Radiator Flush
Old Mar 21, 2009 | 10:20 PM
nbd13's Avatar
nbd13
Default Radiator Flush
Hey guys,
I have an '06 auto GT vert that has a saleen super charger pushing 415 RWHP and 411 torque. I have about 40,000 miles on it and was wondering when and if I should get a radiator flush?
What's the recommend protocol for this?
Thanks,
Nick
Old Mar 21, 2009 | 10:46 PM
atomicpunk's Avatar
atomicpunk
Hey Nick,
If you had this car since it was new and haven't flushed the cooling system yet it's time to do it. I get a bottle of rad. flush and drain a litttle coolant out of the radiator and dump it in and drive the car for couple of days before I flush it. I also replace the thermostat when I flush the cooling system, cheap insurance.
I forget what Ford recommends for cooling system service but I do it every 2-3 years. I put about 8000 miles a year on my cars.
Old Mar 21, 2009 | 11:48 PM
deekum1627's Avatar
deekum1627
i would change it
Old Mar 22, 2009 | 09:35 PM
RedDogGT's Avatar
RedDogGT
Flushing the radiator? Seriously? I've owned many...many vehicles throughout my life time. Had a few past the 300k miles, so I feel somewhat confident in my way of thinking.
Thermostats stick for various reasons. Sometimes age, other times corrosion. Most modern cooling systems on cars (including the Mustang's system) is considered a closed system that under normal circumstances don't need additional fluid to be added. The truth of the matter, the coolant is formulated to do a thorough job of heat transfer without the "50/50" mixing that generic coolants require. That being said, there shouldn't be any corrosion occurring to mess up your thermostat.
You have had an obvious upgrade to your system which required a fluid draining to be performed. Hopefully factory spec fluid was used to refill the coolant system. That still shouldn't require a flushing unless you or someone else is introducing debris/non-spec fluids into the system.
I know opinions are like @ssh0les and everyone's got one but as I've mentioned, I've owned many cars and a few that have surpassed 300k. If you stick with OEM fluids, you don't need to flush your radiator.
4cylinderplus2
Oct 9, 2020 07:45 PM
Granatelli Sales
Jan 20, 2020 12:34 AM
Nov 18, 2015 01:34 PM
wraith777
Sep 28, 2015 10:49 AM
MusicCity615
Sep 12, 2015 07:05 AM
