Wheel Help
Old Mar 28, 2009 | 09:52 AM
TWOKOOL's Avatar
TWOKOOL
Default Wheel Help
Can somebody tell me if these rims will fit my 07 GT?
19" +35 offset
5-4.5 5-114.3
9.5 inch wide
Real good deal is available if they fit.
Old Mar 28, 2009 | 09:57 AM
Poco's Avatar
Poco
Do you know the backspacing? Brand of wheel? They could be a bit wide for the back with that offset causing the tire to stick out,especially if your lowered.
Old Mar 28, 2009 | 10:59 AM
TWOKOOL's Avatar
TWOKOOL
they are TSW, and I am not lowered. 19" x 9.5 35mm all the way around, not staggered
Old Mar 28, 2009 | 11:05 AM
Poco's Avatar
Poco
I remembered that Cruizin Concepts sells those wheels.According to their list of fitments you should be O.K. .Next would be tire sizing.They may have a recommended tire size for you.
http://www.cruizinconcepts.com/musta...ish_wheels.asp
Old Mar 28, 2009 | 02:24 PM
Stetler17's Avatar
Stetler17
I hope they fit I have a set of ADR M Classics on the way...should have them Tuesday.
19 x 8.5 32mm backspacing and 19 x 9.5 35mm backspacing for me.
Most of the FR500's are 10" with a 40mm backspace.
My calculations are that your wheels will be 3.38" out past the mounting surface of the hub and the FR500's would be 3.43" out. (half of the wheels width minus the offset)
That's pretty close to identical....and the FR500's fit perfect. The only concern I would have is on the front with clearance on the inside. That's why I went with the 8.5's up there. They will be similar to the 9" FR500's.
I only use the other wheels as a reference because we all know how well they fit the cars.
Anyone want to chime in? I hope I'm thinking of this the right way...
Old Mar 28, 2009 | 04:09 PM
Poco's Avatar
Poco
There is some guy on an other forum (TSW's)running 18x10's on the front without any clearance issues.
Old Mar 28, 2009 | 05:23 PM
TWOKOOL's Avatar
TWOKOOL
Thanks for all the input guys. I may have to buy them and try em out.
jwog666
Dec 27, 2021 08:09 PM
UrS4
Oct 3, 2015 06:23 AM
mungodrums
Sep 28, 2015 10:54 PM
folivier
Sep 26, 2015 02:28 PM
lincolnshibuya
Sep 24, 2015 10:46 PM
