3m Adhesive Promoter ?
The pen I have and linked to on eBay smells just like a Sanford Black Permenent
Marker from years past just minus the black die/pigments. Not a super glue like substance.
Here is what it is made from.
The main ingredient in Super glue is cyanoacrylate (C5H5NO2, for you chemistry buffs). Cyanoacrylate is an acrylic resin that cures (forms its strongest bond) almost instantly. The only trigger it requires is the hydroxyl ions in water, which is convenient since virtually any object you might wish to glue will have at least trace amounts of water on its surface.
Super glue, undergoes a process called anionic polymerization. The chemical process of polymerization produces a certain amount of heat. If a large enough amount of super glue makes contact with your skin, it can actually cause burns. Cyanoacrylate molecules start linking up when they come into contact with water, and they whip around in chains to form a durable plastic mesh. The glue thickens and hardens until the thrashing molecular strands can no longer move.
The Adhesion Promoter starts the process where the 3M Acrylic tape cures to form a tight bond.
www.bondprousa.com
www.bondprousa.com
jwog666
12-27-2021 08:09 PM
MustangJourney
09-02-2015 04:32 PM
