Shaker 500 CD Error Problem
Old Apr 15, 2009 | 02:23 PM
tfedorka2001's Avatar
tfedorka2001
I had the same problem with my radio. I took it back to the dealer and had it replaced under warrenty.
Old Apr 15, 2009 | 02:39 PM
Doogie65's Avatar
Doogie65
Thanks for input Cutter, but think I may just let the dealer take care of it in lieu of pulling the dash apart. If the unit does indeed need a reset, I would assume disconnecting power via the battery should have solved it and had about the same effect as physically unplugging the head unit.
Old Apr 15, 2009 | 03:55 PM
157dB's Avatar
157dB
Cut & Paste Expert
Did you do a diagnostics test on it?
Old Apr 15, 2009 | 04:33 PM
Doogie65's Avatar
Doogie65
Yes, I did the self test and it passed with no error codes.
Old Apr 20, 2009 | 12:33 AM
mattsimonton's Avatar
mattsimonton
Mine has done that twice. Both times I disconnected the radio and re connected it. It worked both times. For some reason disconnecting just the battery didn't work for me, I think the system held some power and did not fully discharge. However to solve this problem from happening again I drove to Best Buy and picked up the Peripheral Ipod kit and installed that, Haven't had a problem since. Good luck with it!
Old Apr 21, 2009 | 08:57 PM
Doogie65's Avatar
Doogie65
Well, decided to try disconnecting the radio directly and no luck solving the problem. Looks like a trip to the dealer is up next.
And now I am an expert with pulling the radio area apart thanks to one of Tacobill's sticky's
Old May 13, 2009 | 10:37 AM
sportcolbs's Avatar
sportcolbs
My 2006 is out of warranty and the CD error/initializing message is prevelent on the screen. I cannot get the CDs to eject. Ford dealer wanted almost $400 to repair. I purchased another Shaker on eBay for $125 and hopefully install this afternoon. It seems these radios have this occurance quite frequently.
Old May 13, 2009 | 11:33 AM
sportcolbs's Avatar
sportcolbs
Old May 29, 2009 | 10:27 PM
BryantHavercamp's Avatar
BryantHavercamp
My shaker500 was doing that too.... so I bought a shaker1000 off of ebay and installed it. The Shaker1000 that I bought does it too, right off the bat. I never even got a chance to put a cd in. Can you say "epic fail" ?
Old May 30, 2009 | 07:47 AM
sportcolbs's Avatar
sportcolbs
Default Shaker "sucks bigtime" radios
This is not unusual according to the company I got my radio from. The first I received arrived with the same problem. I gave them a call and was told that sometimes in shipping it misaligns the CD heads when the package is dropped or whatever. They sent me another which works fine now.
I sold my old one on eBay for $40 in an "as is" condition. I just wish I knew how to remove the three CD's in it.
