Catch Can fitting help
Old Apr 17, 2009 | 11:37 PM
MexGT's Avatar
MexGT
Default Catch Can fitting help
Well so I bought a Moroso Catch Can with only 1 intlet (dumb me...)
http://www.jegs.com/i/Moroso/710/85470/10002/-1
and I want to make this work with both PCV, so which fittings should I buy now?
I thought about something like this:
(1X) http://store.summitracing.com/partde...5&autoview=sku
(2X) http://store.summitracing.com/partde...5&autoview=sku
so will this make it work for me? Is there a better option for fittings?
I´d hate while screwing the Tee into the can, it will not be horizontal to it and/or the hose ends to the can.
Thanks !
Old Apr 18, 2009 | 05:15 PM
MexGT's Avatar
MexGT
any1?
Old Apr 18, 2009 | 05:53 PM
157dB's Avatar
157dB
Cut & Paste Expert
If you are going AN fittings, thats the selection right there.
But why AN fittings and hose for a simple low pressure
PVC breather hose. Are you going AN/braided on everything
and just want to continue the theme throughout?
The descriptions states two inlets/outlets.
All aluminum, lightweight 3'' x 17-1/2'' (installed) eliminates
the need for two tanks with a larger capacity 2.5 quart tank
complete with dual -12AN fittings allowing hookup from a
vacuum pump and dry sump pump.
Old Apr 18, 2009 | 06:36 PM
MexGT's Avatar
MexGT
Thats the description I guess for the dual intlet, if you see a little lower it says in Notes single female intlet.
jwog666
Dec 27, 2021 08:09 PM
mustangheaven
Jan 3, 2016 11:20 AM
BeatnikFink
Oct 1, 2015 08:00 PM
fastbackford351
Oct 1, 2015 12:24 PM
mdg
Oct 1, 2015 07:04 AM
