Sponsored by:
Sponsored by:
Running the V6 hard this weekend
Old 04-23-2009, 06:53 PM
28HopUp
MF Administrator
28HopUp's Avatar
You youngsters! El Mirage is RICH in history. Although I've never been there, I've read alot about it in the early days after WW2 when guys would hop up their cars and run them flat out. You should have a great time, but your car will get dirty.
Two things to keep in mind regarding your S197 -
  1. If you have a tuner, turn off the speed limiter. Otherwise, it'll back off around 113mph.
  2. If the driveshaft in your 05 has the pressed-in u-joint caps instead of the ones with the retaining clips, then leave the speed limiter on. You don't want to break a driveshaft at speed.
HAVE FUN, and post pics!
28HopUp is offline
Old 04-23-2009, 06:57 PM
Chris07GT
Chris07GT's Avatar
Just make sure your tires are inflated properly, bring a helmet (as it's probably a rule, but if not, a good idea) and let it rip! Wish there was something like that in Florida!
My guess is that you'll get up to about 130-135, maybe 140. Good luck!
Chris07GT is offline
Old 04-23-2009, 08:30 PM
r3velation
r3velation's Avatar
that sounds awesome! we should definitely get a bunch of people out there.
unless my speedo was lying to me, i had the needle all the way at the end on the freeway, then i realized i was going that fast and was like WTF.
r3velation is offline
Old 04-23-2009, 08:35 PM
Rubrignitz
Rubrignitz's Avatar
You guys don't remember Will Smith's famous quote in the movie Independence Day??? He had to get back to El Mirage airbase to go fight the aliens lol. It's been mentioned many, many times in movies and documentaries.
Sounds like you're going to have a blast (pun intended lol).
Rubrignitz is offline
Old 04-23-2009, 09:02 PM
clintster77
clintster77's Avatar
Originally Posted by Lethaldosage423
Dodge neon
about 4 subaru imprez
Anything i need to worry about my car?
Be careful with yours . RWD is more likely to want to hang the rear out than (neon or impreza) I don't know what kind of surface it is as far as the looseness but if the rear begins to swing out don't panic.Do not hit the brake ,if anything feather the gas so you can bring the rear back in behind you slowly. This should keep snap back to a minimum .
letting off the gas in the higher rpm ranges can cause (shift lock/engine brake ) especially with a manual trans on dirt or wet conditions . almost like using the e brake without expecting it .
have fun and I would get the feel of it at lower speeds (under 100) by driving in a giant circle . That is if they allow that .
I'm jealous
clintster77 is offline
Old 04-23-2009, 11:59 PM
Lethaldosage423
Lethaldosage423's Avatar
lol Thanks alot for the advice.
My friend in the F150 said he is going to find the aliens from Independence day lol.
I do have the stock driveshaft but my friend thinks ill be fine because when i try to hit my top speed, im just going to cruise upto it and im not pulling hills or anything.
And a cruise down there is a great idea!
Lethaldosage423 is offline
Old 04-24-2009, 12:12 AM
sonicmetalicS197
sonicmetalicS197's Avatar
is there really a way to tell 100% sure if your DS is one of the "bad" ones and will F up?
sonicmetalicS197 is offline
Old 04-24-2009, 12:14 AM
Red Beast
Red Beast's Avatar
if you set up a cruise then make sure you post on here! im down for that! i just need to get hood pins first and id b good to go!!!
Red Beast is offline
Old 04-24-2009, 07:52 AM
antipeterleague
antipeterleague's Avatar
seems sweet though really, i would hate getting my car that dirty hahaha
antipeterleague is offline
Old 04-24-2009, 08:15 PM
Lethaldosage423
lol dont worry ill post here when i set up a cruise.
and i WILL post pics and videos
and i do hate getting my car dirty, especially since i clayed it and waxed it last saturday lol but hopefully because its so smooth it will come right off!
i cant wait, i just rotated my tires, and torqued the lugs.
Im brining my torque wrench to make sure my lugs stay tight . im also bringing a tire plug kit incase i get a flat. i can put the spare on, plug my tire, drive to the gas station to get air and im good to go again!
im really excited
Quick Reply: Running the V6 hard this weekend
