Should I get the 99-04 rims or wait 2 weeks for the 05+
all the answers to your questions.
Without the offset info, one can only guess.
Brand or link to these 18x9" and 18x10" rims?
Just not enough info for an educated answer.
I am also not sure....
I would be looking into the required steering stops as well....
For vehicles with 17" wheels from the factory:
-installing 18" x 8.5" or 18" x 9.5" wheels, use steering stop 6R3Z-3932-CA
Are the 99-04 rims OEM width of what?
Aftermarket 18x9s for the 05-09 S197?
OEM 18x8.5s have a 50mm offset.
So the 05+ rims with the 36mm offset
will also stick out.
Width effects offset unlike backspacing.
Here is a prime example of a 18x9 with a 40 MM offset plus a 5 mm spacer(35MM offset)and they do not stick out,not even a little.Second pic are 18x8.5's with a 36 mm offset and they fit really good.
This last set was pretty outrageous and I had 295/55/18's on 18x10 with 40mm offset set and they didn't rub or stick out past the fender wells either.Front's are 18x9's with 38 mm offset and 255/45's.No problems there either.
Here is the link for the front 18x9's I have ordered.
http://cruizinconceptswholesale.com/...ACK189&cat=246
Link for rear 18x10's
http://cruizinconceptswholesale.com/...K18X10&cat=246
folivier
Tennessee Regional Chapter
10-02-2015 05:32 AM
