2006 Climate Controll Problem
Old Apr 26, 2009 | 08:43 PM
ExplorerGuy's Avatar
ExplorerGuy
Default 2006 Climate Controll Problem
Hey guys/gals,
Im coming over to you from Explorer Forum. Im a mod over there and I am having some trouble with a 2006 Mustang.
The Climate controls no longer work in my girlfriends car. She drove it one day with the defrost on. She got back in the car and nothing would change. The blower motor is not running but when driving down the road hot hot air comes out the defrost.
You can to control the fan speed, the temp, or where the air comes out at. Also as a side note you can not make the rear defrost work either.
I have checked fuses and relays. What should be my next move?
Thanks,
Burns
Old Apr 27, 2009 | 09:05 AM
157dB's Avatar
157dB
Cut & Paste Expert
Welcome new user by need to fix a problem.
http://iihs.net/fsm/?dir=332&viewfil...l%20System.pdf
Old Apr 28, 2009 | 12:13 AM
ExplorerGuy
I thought that might get posted up here
Thanks for the help.
If anyone else knows of anyone who has had this issue or possibly a recall on something i would be thankful
ExplorerGuy
Old Apr 28, 2009 | 12:28 AM
Buckshot Barry's Avatar
Buckshot Barry
Anytime I see an electrical problem I always think of the dreaded leak issue.
Have you checked the passenger floor board for dampness. Especially up against the kick panel?
Old Apr 28, 2009 | 12:31 AM
ExplorerGuy
Leak issue? What issue do these cars have?
Ill check it but have not notices anything
Old Apr 28, 2009 | 12:47 AM
Buckshot Barry
https://mustangforums.com/forum/2005...-mustangs.html
and about 25 other threads. Water can come in the cabin from a few places and most of the time gets an electrical module wet, which can short out and cause all kinds of issues.
Old Apr 28, 2009 | 10:53 AM
157dB's Avatar
157dB
Cut & Paste Expert
But the CCM is mounted in a different location than the
ever so often water logged SJB.
Climate Control problems are usually not indicitive of the water leak..
So not all electrical problems are associated with the
corroded SJB problem...
Old Apr 29, 2009 | 11:18 PM
ExplorerGuy
Friday i am going to work on the car.
Im suspecting the EMTC Module (aka the climate control assembly) to be messed up or just shot.
I have found the ways to test it and am not really looking forward to it.
Nick Oliver
Oct 17, 2018 04:22 AM
PullTab
Oct 30, 2015 08:46 AM
Mustangmalo
Sep 6, 2015 05:22 PM
Sep 3, 2015 07:14 PM
