saving weight???
Old May 8, 2009 | 08:58 AM
Poco's Avatar
Poco
Talking
I'm on a diet, I'd lose enough to keep the back seat in there,maybe even the spare tire.I only need one.
Old May 8, 2009 | 10:34 AM
Mishri's Avatar
Mishri
Mish-ogynist
one thing that article you linked to is a bit off about is the driveshaft.. ours weighs 39lbs! thats huge for a driveshaft.. they are taking a 17lbs and going down to like a 13lb one and saying it helps but its not like getting lighter wheels. In our case going from 39lbs to 15 is a big difference in power. I wonder if anyone has ever done a dyno test to see how much more power you put down after switching...
Old May 8, 2009 | 10:46 AM
2005GTS197's Avatar
2005GTS197
yes the d/s is a nice weight reduction..i would like to get one down the road.
Old May 8, 2009 | 10:54 AM
MELLOWYELLOW06's Avatar
MELLOWYELLOW06
Light weight wheels and tires, driveshaft and keep an empty trunk and remove 1000 subs if you got any, keep gas at 1/2 tank or a hair less if you are driving it daily. Do not do the drastic measures unless you are on the track only with this car, because the rewards of time gain vs. the inconveniences that come from removing your spare, back seat, soun deadening, etc, is just not worth the risk.
Old May 8, 2009 | 11:23 AM
cobrakiller347's Avatar
cobrakiller347
hmm spend 6k for a supercharger and say f*** weight!! it sounds like alot more fun to me lol
Old May 8, 2009 | 11:24 AM
Riptide's Avatar
Riptide
How much does the spare save you?
Old May 8, 2009 | 11:31 AM
2005GTS197's Avatar
2005GTS197
32-34 lbs including jack.
Old May 8, 2009 | 12:06 PM
ahddm's Avatar
ahddm
I've thought about this route but given my method was much more extreme.
Basic parts to remove
Some simple things you can do is remove seats all of them replace driver with race seat and passenger if you need. Remove headliner, if you remove spare take out the trunk floor board also.
With modding
All above + driveshaft, BMR wieght reduction level 2, lightweight wheels/tires and fiberglass hood/fenders.
With the set ups above you can still street the car without much inconvienence.
Major
Above+ remove all flooring, airbags, insulation, replace gas tank for fuelcell, cf doors (make sure they the ones that actually save wieght forgot if it wet or dry), remove windows, and replace windshields with clear plastic. Remove exaust.
Godlike
Above+
Have body redone in fiberglass no insulation, and frame redone in aluminum.
As with what everyone else said unless tracking is a priority then not worth going to far. If you enjoy tracking top 2 setups will give you good reduction while keeping streetablility. If you want complete track setup the third one. If you plan on going against supercars godlike setup will let you compete with anything
Old May 8, 2009 | 01:13 PM
abarker8541's Avatar
abarker8541
no go for a light weight flywheel if you want a high performance application
Old May 8, 2009 | 01:37 PM
2005GTS197's Avatar
2005GTS197
What is the weight savings of the BMR reduction level 2? And how much does it cost?
