saving weight???
Old May 8, 2009 | 01:45 PM
  #21
MELLOWYELLOW06's Avatar
MELLOWYELLOW06
May I suggest a tubular K member?
Got this froma site that sells Kmembers. Do a research to see which is better but I see an instant weight saving here.
BMR's tubular K-member uses an integrated mount system, saving up to 5 lbs. over the competitions' designs. The OE K-member with motor mounts weighs 44 lbs. while the integrated design weighs only 24 lbs., a 20 lb. weight reduction. Designed to be used with BMR or factory A-arms and spindles. Fits V6 and V8 models.
Old May 8, 2009 | 01:49 PM
  #22
2005GTS197's Avatar
2005GTS197
Sure. What is the weight savings on the K member?
Old May 8, 2009 | 02:56 PM
  #23
2005GTS197's Avatar
2005GTS197
oops didnt read your entire message. I am going to look into this.
Old May 8, 2009 | 04:00 PM
  #24
1morepart's Avatar
1morepart
try the "search" option....this question has been answered. i will try to find you the link, but it breaks down everything and tells the weight savings. good luck
baddog671
Jul 26, 2016 01:20 PM
uedlose
The Racers Bench
Oct 1, 2015 08:31 PM
Steve@CJPP
CJ Pony Parts
Sep 24, 2015 02:51 PM
Boostaddict
Lethal Performance
Sep 8, 2015 09:56 PM
