Midpipe issue
Old May 20, 2009 | 03:14 PM
mynameismike65's Avatar
mynameismike65
Default Midpipe issue
Got o/r prochamber installed.....now there is a rattle/vibration in first gear under 2500 rpm. I can feel it through the floorboards and in my right foot. Its most noticable when the wheels are slightly turned. Its only down low and I cant see anything touching from underneath....but IDK. Can someone give me some advice?
Old May 20, 2009 | 04:44 PM
jahudso2's Avatar
jahudso2
When does it happen? Accelerating, decelerating, coasting down, cruising at a constant speed? Does it only happen in first gear?
Old May 20, 2009 | 05:51 PM
mynameismike65
Its most noticable in first gear while the wheels are turned left.....its almost like I can feel something vibrating/rattling on the floor boards....I can hear it too. Its only down low though.
Old May 20, 2009 | 10:40 PM
MadMike1337's Avatar
MadMike1337
do you have enough clearence? bolts tight?
Old May 21, 2009 | 04:11 PM
smokestang's Avatar
smokestang
I would check and make sure you tightened everything up again! also check your midpipe hangers(since you have an 06) to make sure one of them didnt pop out. I had that same problem on my 07 and it was the midpipe hanger that wasnt all the way in place!
Old May 21, 2009 | 04:32 PM
jahudso2's Avatar
jahudso2
Oh yeah, check the metal hangers for the mid pipe. The part that attaches to the transmission cross member is a rubber hanger, but has a metal surrounding. If the metal surrounding is making contact with the metal hanger welded to the exhaust, then you have a rattle.
Old May 21, 2009 | 05:41 PM
mynameismike65
Its not really a metalic rattle....its weird.
Old May 21, 2009 | 06:39 PM
jahudso2's Avatar
jahudso2
It is hard to get an idea for what it might be through your explanation. Can you get a sound clip off your cell phone or movie camera?
cr620
Oct 3, 2022 10:18 PM
lincolnshibuya
Dec 8, 2015 04:37 PM
Thunderball
15
Nov 22, 2015 11:49 PM
chrisdbassplayer
Oct 13, 2015 06:53 PM
Bokeo
Oct 10, 2015 08:28 PM
