How To: Change Differential Fluid
Old Oct 2, 2009 | 03:51 PM
  #51
157dB's Avatar
157dB
Cut & Paste Expert
Holy moses....
Double post Batman
Old Oct 2, 2009 | 03:52 PM
  #52
157dB's Avatar
157dB
Cut & Paste Expert
Jeees, first picture is of jacking by the pumpkin.
I thouth this was a 'how to', not a 'how not to...'
My stomach is turning a little right now...
You have 100,000 miles on that 07 already to
warrant a synthetic rear end lube change?
Old Oct 2, 2009 | 06:31 PM
  #53
scorpio333's Avatar
scorpio333
He did it by the pumPkin, not the pumkin so it's all good.
Old Oct 2, 2009 | 07:21 PM
  #54
degeze's Avatar
degeze
^ It has about 75k, it's an 06 and you already know I enjoy jacking the pumpkin. Hey, you are lucky I used jack stands .
To All: This write-up is ONLY to provide helpful information, tips and pics on the process of changing the fluid. If you don't agree with changing the fluid...then don't. I changed mine and was happy with the results so I decided to put this together to help out other members if they had plans of doing the same. That's it...nothing more nothing less.
Old Oct 25, 2009 | 10:00 PM
  #55
nagata's Avatar
nagata
Well, regardless of what some others may think, I want to thank you for the write-up, degeze! I had to pull the rear diff covet off my 96 GT because it developed a leak, and even tho it's not exactly the same car, your write up was very helpful in changing the fluid and resealing the cover. The process did take me forever because I kept running into little hang ups, but it's done, and hopefully I won't have to deal with a leak ever again! I will say that the most pain in the *** part was refilling the housing, that part just sucks! I ended up getting a small pump and that worked wonders, but only after I spent a good hour screwing around trying other methods. Thanks again!
Old Oct 26, 2009 | 06:21 AM
  #56
degeze's Avatar
degeze
^ You're welcome, glad it was able to help.
Old Oct 26, 2009 | 07:48 AM
  #57
05 Mustang's Avatar
05 Mustang
Darren's the man!!!
mtgldr
Feb 3, 2024 09:00 PM
mungodrums
Oct 7, 2015 04:01 AM
LivingInThePast
Sep 16, 2015 12:20 PM
SteelerNation82
Sep 16, 2015 07:11 AM
Pyrate Dave
Sep 10, 2015 07:30 PM
