jba LT quick question
Old Jun 5, 2009 | 11:10 PM
david01130's Avatar
david01130
Default jba LT quick question
for all those who told me the stock studs would work with the jba LTs are wrong. they hit the headers when you put them on since they are so long. So whats my best option now? My car is half apart and was hoping to finish this tonight but I guess I cant. Where can I get a new set of header bolts fast? Do you think a local place would have them? If not what and where should I get a set?
Old Jun 5, 2009 | 11:37 PM
KLO's Avatar
KLO
Just a quick suggestion. When you have a question that specific just call up JBA, they will know the answer and it'll be quick instead of waiting around for an answer on a forum. I would suggest picking up Stage 8 locking bolts, but you're gonna have to order those puppies. My recommendation is to take a stud out and go to your local Home Depot or Lowe's or whatever you have and pick up a set of 16 bolts that will work for the time being. Then I would order the locking fasteners and switch them later. At least it will get the car driveable for the time being.
Old Jun 5, 2009 | 11:42 PM
david01130's Avatar
david01130
yea I was going to call around including jba but everything is closed now so I thought I would just throw this up here. It looks like the locking FRPP or stage 8 bolts are the way to go. Maybe theres a place local that has them. Buying some cheap bolts for the time being is not a bad idea.
Old Jun 8, 2009 | 01:19 PM
david01130's Avatar
david01130
Got the headers in. Extremely difficult. Especially since I was on my own. Whoever said all I needed were 2 O2 extensions is wrong again. I need one more. Looks like there are two different kinds of connections. 2 have green connectors and 2 have blue ones. The O2 sensor extensions I bought are for the blue ones. I need one for the green one. Anyone know where I can get them? I called around locally and no one has them. Also can I just install the O2 sensor and not have it connected for a few days so at least I can drive the car around?
Old Jun 8, 2009 | 01:32 PM
05slpGT's Avatar
05slpGT
They i would install it just because if you dont you will have a nice exhaust leak, but either way, your CEL will be on. Have you tried to put the "blue extension into the green connector and see if you run any CEL? It might not matter. Did the extensions you have come with the headers? Not all companies to but i know a few that do. If not, which set of 02 extensions did you get. I can get you BBK extensions if you need them just lemme know.
Old Jun 8, 2009 | 02:11 PM
david01130's Avatar
david01130
jba includes extensions in their kit but I bought mine used from a guy and he just gave me the headers and nothing else. I was planning on plugging the actual sensor in the hole just not connecting the wires. I called JBA and they said the front two senors should be plugged in but the back two are less important but may still throw a code. I think Im just going to buy another set of extensions. I think Im going to buy the same extensions I bought before but thanks though.
Old Jun 8, 2009 | 02:35 PM
05slpGT's Avatar
05slpGT
Ok sounds good. Also, im not sure if SCT or diablo still has this option in the programming, but if you have one of those tuners you could your tuner and ask them to send you a tune with those 2 02 sensors disabled... but im not sure if that will work anymore.
Old Jun 10, 2009 | 07:14 AM
usc49erfan's Avatar
usc49erfan
for the back two you can use a tuner to disable them, i did, just ask bamachips and they get you tune that will disable them
tmdm
May 2, 2021 02:49 PM
svfetter
Oct 5, 2015 11:39 AM
Big Al's 03
Sep 15, 2015 09:05 AM
Mustangmalo
Sep 6, 2015 05:22 PM
