how common were the leaking problems??
Old Jun 12, 2009 | 05:02 PM
cummins cowboy's Avatar
cummins cowboy
Default how common were the leaking problems??
I was wondering how common the leaking problems are with the 05-09 GT's. was the problem cured with the '07 and later models??
Old Jun 12, 2009 | 05:53 PM
trigger06's Avatar
trigger06
I've got an 05 and dont have any problems
Old Jun 12, 2009 | 06:00 PM
NaplesFL11GT's Avatar
NaplesFL11GT
I have my 05 for a few yrs and no known leaks whatsoever.
Old Jun 12, 2009 | 06:02 PM
2cokeman's Avatar
2cokeman
4 S197's and no leaks
Old Jun 12, 2009 | 06:39 PM
mustangfan87's Avatar
mustangfan87
Got an 05 and i had a huge leak. The first time i drove the car after it was raining all day, it sounded like someone was pouring water in the passenger side footwell. I have fixed it since than.
Old Jun 12, 2009 | 06:53 PM
moosestang's Avatar
moosestang
Fairly common i'd say and unless you lift up your carpet on the passenger side, you may never know it's leaking. Mine leaked enough to make the insulation wet, but not enough to soak through the carpet.
Old Jun 12, 2009 | 08:33 PM
digitalcos's Avatar
digitalcos
My '07 leaked. Not bad enough to soak the floor so I'd see that it was leaking, just bad enough to get into the SJB and mess with the electronics. Good times.
Old Jun 12, 2009 | 08:36 PM
americaniron's Avatar
americaniron
I had it and it was fixed as per the TSB. That was a couple years ago, and no more problems since. It was most previlent in 05,and 06 models, but I have heard of some folks with later year models having the problem.
Old Jun 12, 2009 | 11:15 PM
White05GT's Avatar
White05GT
I had it and 2 other people i know did too. All 05's and all fixed under TSB.
Old Jun 14, 2009 | 01:42 AM
HypromanGT's Avatar
HypromanGT
+10 I think probably a fair amount of these cars may have some variation of this leak problem and their owners will never know it. I would bet that a large percentage of these cars probably rarely see heavy rain, are garage queens, sunny day driven, etc, and as stated it's not something that is easily recognizable unless you're actively looking.
I had my 06 car for 7+ months as a daily driver before noticing that I had this problem, and actually I didn't even find it myself; a friend riding in the passenger seat had sandals on and happen to kick them off in the car and noticed that the entire carpet (including my stock mats) were soaked. That's when I started paying attention (thought I had left the window open or something), and sure enough, the next rain storm I had another soaking wet carpet.
That said, my 08 is dry as can be (and I checked it A LOT in the first few months I had it, and still do every once in a while, just because of all the bad memories).
