manual . shifting question
Old Jun 21, 2009 | 01:39 AM
overcome1236's Avatar
overcome1236
Default manual . shifting question
im kinda new to driving stick and i feel like everytime i go quick in 1st gear and shift to 2nd its not that smooth idk if thats just b.c im going fast and its normal not to be smooth but 2-3 ,3-4 ,4-5 all feel so much smoother.... idk if im not adding enough gas when i let off the clutch or what? if any1 has any tips or anything id appreciate bc i want to do everything right.
Old Jun 21, 2009 | 02:01 AM
overcome1236
or am i shifting too slow and the rpms are dropping to much
Old Jun 21, 2009 | 02:30 AM
mygt500's Avatar
mygt500
Multi-Tasking Moderator!
Might be the dreaded engine torquing over too much and with the way the trans connects to the shifter and its mounting location on the trans causing the need for motor mounts or CHE K member brace with TQ limiters.......or just need some more practice!
So this happens at WOT right? IF so its time for a simple mod....either the motor mounts or the TQ limiters....most dont need both.
Old Jun 21, 2009 | 03:32 AM
overcome1236
well I def need practice there's nothing wrong with the car I'm just not sure what I'm doing wrong but I want to practice doing it right so if you can help me in anyway I'd appreciate and any other tips on shifting .. Thank you
Old Jun 21, 2009 | 03:53 AM
mygt500's Avatar
mygt500
SO were you having this issue with Wide Open Throttle (WOT)? Reason why I ask as it apparantly is a design overlook with the S197 that requires for some (like myself) stiffer motor mounts or torque limiters for shifting that is harder when going from first to second at WOT. Not saying anything is wrong with the car as nothing was wrong with mine either but felt the mod was necessary for better and faster shifts when the car's motor is under a load like going WOT
Old Jun 21, 2009 | 09:56 AM
06 Gt on 20s's Avatar
06 Gt on 20s
Which would you get first limiters or mounts?
Old Jun 21, 2009 | 10:51 AM
JDWalton's Avatar
JDWalton
I like the limiters just cause I like the appeal of the extra brace. Also, the reinforcement comes near the shifter so there is less flex closer to the position you need it.
http://www.brenspeed.com/che7la.html
Also, to the OP. Do you have some you trust that has driven standard a lot and you can go for a ride with them? Someone that will just drive it and not beat on it so you can see clearly if it is your driving or if it is something flexing more then you want. That would be a easy way to see what it is. Also you can pick there brain about what specifically your doing wrong (if anything.) Hard to critique your driving over the interned.
Old Jun 21, 2009 | 11:56 AM
deekum1627's Avatar
deekum1627
i like the che k-member with tq limiters
Old Jun 21, 2009 | 12:33 PM
08_gt's Avatar
08_gt
practice makes perfect. might be shifting to second too soon?
Old Jun 21, 2009 | 01:11 PM
overcome1236
I have a 91 bamachop torque tune n everytime I ask my friend for tips he's like idk man just drive the car doesn't help much but he's awesome at manual
