Saleen Pulley Change
Anyone changed from a stock 3.8 or 3.6 pulley to a 3.4? And have any numbers of rwhp increase?
I just swapped out my supershaker stock pulley (3.86 I think) to a 3.4, added a KB BAP, Brisk plugs, and of course a Brenspeed updated tune.
What would you expect for gains? Seat of the pants, not sure I noticed a thing....maybe a little more pull. I gotta get this thing on a dyno, but never did get a baseline of the stock shaker...
i dont belive they compound...when i was talking to the install shop and brenseed they said the
4.0 = 5-5.5 psi
3.8 = 6-6.5 psi
3.6 = 7-7.5psi
3.4 = 8-8.5 psi
3.2 = 9.5 psi
of course this will all be different depending on where you live and what mods you have. example an off road x pipe will lower your boost BUT make more HP due to the back pressure
4.0 = 5-5.5 psi
3.8 = 6-6.5 psi
3.6 = 7-7.5psi
3.4 = 8-8.5 psi
3.2 = 9.5 psi
3.8 to a 3.4 i gained about 40 rwhp but the tune has to be there.....i now run the 3.0 pulley, 60 pound injectors, dual fuel pump 113mm maf and such.....currently 595 rwhp on 104 and 550 rwhp on 91 octain.......on the 3.8 pully i was only putting down like 375 rwhp... on the 3.4 i beleive i was around 450 rwhp....JDM has done all my tuning and i couldnt be happier...i also live at high altitude so i can get away with running my timing alot more advanced
