additional things for long tubes install?
Old Aug 16, 2009 | 01:44 PM
  #31
GA05GT's Avatar
GA05GT
Driving the car w/ touching headers..?
I would not bend (with heat) the headers you will only weaken the material of the headers/ create hairline cracks near the flanges from the stress of bending. If I was in your shoes I would have the headers cut near the flange (not completely off just enough to bend the tube) then full weld to eliminate any form of leaks or fatigue. The proper way to weld the stainless is with a TIG welder, MIG is too inconsistent unless you have the correct shielding gas/ wire.
Hope this helps, Good luck!
Old Aug 23, 2009 | 05:47 PM
  #32
jlugo_70's Avatar
jlugo_70
ok so got car back last week and man does the hurst and 4.10's make the mustang way better. as for the longtubes they werent able to install them because they said that they did not clear. i will upload pics later for u guys to see where the headers hit
Old Aug 23, 2009 | 06:11 PM
  #33
Rubrignitz's Avatar
Rubrignitz
Word to the wise... never try to go "cheap" with longtubes. good quality headers and motor mounts will save a lot of headaches in the long run.
Old Aug 23, 2009 | 06:14 PM
  #34
Rubrignitz's Avatar
Rubrignitz
Originally Posted by shanec
No, it isn't. Motor mounts have nothing to do with the fitment of LT headers. People put in motor mounts since the stockers often need to be removed anyway to get the LT's in.
My headers banged the frame w/o new mounts. I drove for a week listening to the headers banging. After installing the new steeda MM's no problem.
You're correct in your statement about motor mounts having nothing to do with FITMENT but they allow the engine to move under load causing contact.
msavoia23
12
Jul 7, 2018 12:08 PM
Gary Ugarek
Sep 5, 2015 09:03 PM
5.0pntydrpr
Aug 27, 2015 10:26 PM
prophotog
Aug 26, 2015 11:55 AM
Evilwilly
Aug 25, 2015 10:30 PM
