Convertable Upkeep
Old Jul 26, 2009 | 07:04 PM
rmp102's Avatar
rmp102
Default Convertable Upkeep
Hey guys ............ Now that I have this 2010 Mustang convertable, How should I maintain the roof? It is garage kept and will not spend large periods of time in the elements, but being new to the "rag top", I am wondering how to keep it in perfect condition.
Old Jul 29, 2009 | 11:13 PM
Beach Blvd's Avatar
Beach Blvd
Grats on your pony.
I had a 93 convertible, replaced it with a 00 convertible and never had to replace anything related to the top on either one.
Random thoughts:
Garage kept is most important, with the top up.
Put the windows down when raising/lowering the top. Some other convertibles do this now automatically, I'm not sure if mustangs do or not.
I put some kind of lube or WD40 on the top's hinges maybe once a year.
You don't have to scrub it too much to keep it clean, especially now since I think they only come in black. Avoid automatic car washes. Never buy a car with a white convertible top.
I think Armor all is a waste of time because if it is sunny out you want the top down anyway and it will get all over your rear window.
Old Jul 29, 2009 | 11:40 PM
icody's Avatar
icody
The 2010 Mustang Convertible does automatically roll the windows down when the top is retracted and again when you raise the top. The Material on todays Ragtops are much better than used in the past and do not flap in the wind and can withstand a lot more abuse that earlier cars.
Old Jul 30, 2009 | 12:06 PM
rmp102's Avatar
rmp102
Thanks ............ It looks like it is well made and that being garage kept that it will do alot in keeping it's appearance. I wanted a light top, but you as well as my friends agree ..... keep it dark .... glad I did!
Old Jul 30, 2009 | 03:16 PM
wilkinda's Avatar
wilkinda
2010 Section Moderator
If I am not mistaken, the new top is clothe like anyways so no need for Armour All at all.
Old Jul 31, 2009 | 04:35 PM
rmp102's Avatar
rmp102
No ... The GT is cloth ...... Mine is the V6 Premium .... It's vinyl
Old Aug 1, 2009 | 12:11 PM
Orion_240's Avatar
Orion_240
I have the cloth top on my 2008 and I just wash and dry it like a normal roof. But when it is dry I use one of those lint rollers to get any cat hair (stupid alley cats!) off. I try to keep my vert covered, but if it gets dirty and I don't have time to wash it I leave the cover off and the cats walk all over it! Going to lay out more cayenne pepper today!
Also if you have the top down watch out when doing any fast acceleration. The top (when it is down) fills with air and starts to rise at about 90 mph! I am guessing the cover would prevent this. It's a little scary punching it on a deserted stretch of highway and then seeing a rear view mirror full of your roof coming up!
Old Feb 21, 2010 | 07:10 AM
SalManilla's Avatar
SalManilla
I have an 05 with a Tan Top. Any suggestions on Cleaning it? I have had No luck in keeping it clean.
Old Feb 21, 2010 | 05:51 PM
jklimczak's Avatar
jklimczak
ya i have 2010 and mine is out side all the time should i do any thing to keep it up
Old Feb 22, 2010 | 12:42 PM
Slick61's Avatar
Slick61
I've had both cloth and vinyl tops on my Mustang(s). Each type has its own perils.
The vinyl seems more prone to getting fine little cuts in it when folded. But the cloth has a tendency to get somewhat burnished (rubbing against itself) when folded, creating an inconsistent appearance.
While I prefer the look of a lighter-colored top (it's also a bit cooler), they are a nightmare to keep clean. Had a white vinyl top on my '01 that always looked dirty. Every time I put it down, dirt got ground into the folds & was next to impossible to get out. The parchment-colored tops are similar, but also don't seem to age well if outside a lot... their color changes over time & they just end up looking dirty all the time. Because of that, when I bought my '05 last fall, I said "NO MORE LIGHT-COLORED TOPS!" & got another black one. They're insulated pretty well, so heat intrusion isn't too bad... and any defects stay pretty well hidden.
As for maintenance, there are any number of specialty products... namely Ragg Toppe... they have cleaners/conditioners for both vinyl and cloth. Or, you can stop by your local RV store & see what cleaners they have for vinyl or cloth awnings & such. Vinyl's a bit easier to care for, & you don't have to worry about lint. I give it a good scrubbing when I wash the car, then hit it with some 303 Aerospace protectant when it's dry. The 303 has some UV blockers in it, and it gives a little bit of sheen, without being greasy. It's water-based tho, so it doesn't hold up to rain very well.
Good luck-
cr620
Oct 3, 2022 10:18 PM
lincolnshibuya
Jul 5, 2020 03:05 AM
lovesilver
Members Mustangs
May 9, 2019 09:18 PM
jerrytubes
Oct 23, 2015 12:11 PM
guitarman376
Sep 30, 2015 05:54 PM
