What do i need for a Strong drivetrain
You could just get some stronger 31 spline axles. Then get some carbon clutches to put into your diff. Not sure if you are planning on doing it yourself or not but its not too hard.
I would also look at getting a clutch.
http://www.summitracing.com/parts/CTF-DF611679/
Other than that everything else should hold.
The driveshaft is the weak point, the mustang drivetrain is extremely strong, it's taken from a truck i would assume and it was cheaper to leave it strong than make a new rear end, engineering is a very expensive resource. The 7.5 rear end was too weak so that's how it worked.
I'm following this thread because I was thinking about the same thing as the OP. I plan to get boosted by the end of the year. Gonna go with the Procharger P-1SC-1 kit or maybe the Saleen Super Shaker. I know the two are totally different in boost characteristics but I'm still debating. Can the stock drivetrain handle the instant boost of the Saleen?
Well ...... with 500 + RWHP, I hope you are or planning on getting FORGED as well..!!
10-01-2015 05:13 PM
treesloth
09-28-2015 07:03 AM
09-17-2015 07:32 PM
