Quick Question...
Old Aug 15, 2009 | 04:43 PM
NavAv's Avatar
NavAv
Default Quick Question...
I have a set of wheels and tires originally off of a Roush 428R and i need to top off the tire pressure. Are these tires filled with nitrogen or plain 'ol air? And if it is nitrogen, can I add regular air to top em off?
Thanks!!
Old Aug 15, 2009 | 05:13 PM
157dB's Avatar
157dB
Cut & Paste Expert
air is 70$ nitrogen so topping them off with air is OK.
They will have green valve caps if they have pure (ha ha) nitrogen in them.
Old Aug 16, 2009 | 12:10 AM
JasperGT's Avatar
JasperGT
Air is actually ~80% nitrogen, so you will be fine. I had nitrogen in my tires, but then I moved and none of the dealerships had nitrogen so I just used regular air.
Old Aug 16, 2009 | 04:10 AM
sonicmetalicS197's Avatar
sonicmetalicS197
Is a 100% nitrogen fill REALLY noticable?
Old Aug 16, 2009 | 09:55 AM
S197GT07's Avatar
S197GT07
I just had mine filled with nitrogen at the dealer because they screwed a few things up, and i cant really tell a difference. Also my valve caps are blue
Old Aug 16, 2009 | 10:21 AM
JOHNNY's Avatar
JOHNNY
If their filled with nitrogen it should have a green or blue valve cap, yes you could use air if nitrogen not avalible, their is another thread with nitrogen air debate it works for me in Fl.
Old Aug 16, 2009 | 01:53 PM
NavAv's Avatar
NavAv
awesome, thanks for the info everyone
Old Aug 16, 2009 | 05:17 PM
HoorayBeer's Avatar
HoorayBeer
there is actually 78.09% nitrogen in air. god!
Old Aug 16, 2009 | 06:43 PM
Solitear's Avatar
Solitear
TBH wth is the point in doing nitro fills(i have reg air had nitro before and i feel no dif) >_>
Old Aug 16, 2009 | 06:53 PM
Art161's Avatar
Art161
Supposedly, the advantages of nitrogen are:
1) Less variation of tire pressure with temperature changes.
2) Less chance of the tires rotting on the inside.
3) Less pressure loss over time. Tires filled with regular air tend to lose .5-1 psi per month even if the vehicle is not driven.
Stone629
The Racers Bench
66
Jun 2, 2016 09:52 PM
svfetter
Oct 5, 2015 11:39 AM
Florida Regional Chapter
Sep 30, 2015 08:04 PM
Sep 25, 2015 06:30 PM
