Does synthetic motor oil require tune?
This may be a stupid question, but I thought I would ask anyways. Does synthetic motor oil require tune?
Also, I am having the car brought in tomorrow for the TSB for the strut issue and a clanking/spitting sound from under the car. Is there anything else I should say to the dealership? I was thinking synthetic motor oil, but want feedback first. And yes, I have looked through the posts regarding the synthetic and want to hear thoughts once more.
Greg
Greg
RE: Deos synthetic motor oil require tune?
No tune needed for syn oil.
I did my first change at 2500 miles (used 5W-20 Castrol Syntec), and I plan on changing every 2500 miles. I run my pony hard, so this is cheap insurance.
ORIGINAL: GWFoos
Don:
Are you changing the oil and filter yourself? If so, what filter did you use?
Thanks.
Don:
Thanks.
I think you are fine, assuming a mechanic I know told me the same info. I changed out my oil around 1500 miles as well with Mobil1 Synthetic and I was pretty sure (at least at the time) that I could notice a difference. Anyhow, I don't see the harm in replacing the factory oil that probably had small amounts of factory crap in it as well.
I got 3000+ mi on mine.. I was thinking baout going to speedy lube and using the mobil 1 ..do they have the right oil? what do you guys think.. I cant do it at him..
Just to clarify, I wasnt recommending you wail till 5000 miles before your first oil change, you should have changed it at least twice by then, after that go to synthetic. I like to be sure its well broken in before going to synthetic. 2500 is fine, I wait till 5000 to make it easier to remember to do it every 5000.
Purolator Pure One (PL24651) is one of the best filter you can get. $5.88 at advance auto parts.
