New Gears installing today x3 instructions?
Old Sep 15, 2009 | 08:16 AM
darwin06's Avatar
darwin06
Default New Gears installing today x3 instructions?
In shop now. When I pick it up I want to fix the speedometer and have the sctX3. How do I do this as the upgrade is not in my tune. Search is frustrating as there seems to be no How to or instructions that came with the tool from the dealer. Easy fix?
Any help?
Thanks.
Old Sep 15, 2009 | 08:35 AM
S197GT07's Avatar
S197GT07
Plug it in, and upload a tune.
before it uploads the tune you will be able to change settings, like spark, rev limiter, and other random crap. One of the options is to change your rear gear, so change it, and then upload the tune.
Good luck
Old Sep 15, 2009 | 08:36 AM
d4rb's Avatar
d4rb
I can't speak for the X3, but in the X2 there was a part right before you load the tune to change optional parameters. You can set your gear ratio there.
Old Sep 15, 2009 | 08:40 AM
Misbehavin's Avatar
Misbehavin
Depending upon how the tuner setup your device, you should be able to go into the advanced options (I'm doing this from memory so bear with me) right after you select your tune, but before you actually start the flashing process.
There are two choices there, I believe they are called "Advanced Options" and "Skip Options". You want Advanced options. You can change the rear end ratio and tire height if needed. Bear in mind that some tuners may lock these options and do not permit them to be altered. I know it's available in my Bama Tune.
Old Sep 15, 2009 | 09:22 PM
darwin06's Avatar
darwin06
Advice correct and Done, and thanks again to those that responded.
jwog666
Dec 27, 2021 08:09 PM
carid
Jul 8, 2016 09:55 AM
yourmom6990
3.7L V6 Technical Discussions
Oct 14, 2015 10:08 PM
Urambo Tauro
Sep 7, 2015 12:47 PM
dseg
AmericanMuscle.com
Aug 10, 2015 03:29 PM
