Sponsored by:
Sponsored by:
Help! Convertible top won't go down!
Old 09-30-2009, 07:47 PM
madscientist
madscientist's Avatar
Default Help! Convertible top won't go down!
Hi,
I have recently purchased a 2006 GT convertible with 42K and after a couple of weeks in my possession I have found that the top goes down intermittently. That is I can always power it up but it might go down the first time I try and back up but then when I try to repeat a few minutes later it will not go back down. It always goes back up (I can hear the motor turning if I press the up switch even when it is in the latched up position. I have narrowed it down to the switch or the mini relay #31. Has anyone had similar issues? If so have you replaced the switch and how tricky is it? It is no trouble to replace the relay if necessary.
I should note that when the top does not go down neither do the windows. This leads me to believe it may be the switch. Finally I have yet to switch the up and down mini relays; I will do so when the top stalls again in the down mode.
Thanks for the help!
Eric
madscientist is offline
zsmart
Convertible Tech
02-29-2016 08:33 AM
GPR
12-16-2015 12:21 PM
LivingInThePast
09-16-2015 12:20 PM
Mikett
09-12-2015 10:52 PM
Quick Reply: Help! Convertible top won't go down!
