SC kit with cams
Old Oct 1, 2009 | 01:11 PM
top00cat's Avatar
top00cat
Default SC kit with cams
is there any specific supercharger kit that would work best with frpp hot rod cams?
Old Oct 1, 2009 | 02:08 PM
SirKnightTG's Avatar
SirKnightTG
Your question is actually backwards. You choose a cam for your application, not the other way around. The FRPP Hot Rod cams are made for a N/A engine. If you want maximum gains from a cam and a s/c'er you need a blower grind, which the Hot Rods are not.
But, people run the Hot Rods with s/c'ers of all kinds and they work fine.
Comp Cams has several blower grinds that have the same kind of rough idle the Hot Rods do. BBR does as well.
Old Oct 1, 2009 | 03:13 PM
hammeron's Avatar
hammeron
what's up top00cat
imo the best one would be one that your local dyno tuner can work with. in the end, the way your car will behave is in your tuners hands.
Old Oct 1, 2009 | 07:08 PM
top00cat's Avatar
top00cat
thanks guys. I am starting to look around and gather info. just not sure if i want to go centrificul or twin screw
GimpyHSHS
19
Dec 19, 2023 01:12 PM
jwog666
Dec 27, 2021 08:09 PM
patchshaffer
Tuner Central
Oct 5, 2015 02:24 PM
uedlose
The Racers Bench
Oct 1, 2015 08:31 PM
