gear installation...
Old Oct 17, 2009 | 10:53 AM
scapegoat's Avatar
scapegoat
Default gear installation...
yay, more gear questions...
i've decided to pick up ford racing 4.10's relatively soon.
my questions are about the installation of the gears. I'm a do it yourselfer... despite having very limited mechanical background. how difficult would this job be in a garage w/ no lift?
would anything, other than the gears, be required? i've got under 3k on the car now. obviously i'll need to add new gear oil, but is there anything else that needs to be done, replaced, etc?
Old Oct 17, 2009 | 11:08 AM
Lv XLR8N's Avatar
Lv XLR8N
This isn't the " do it yourselfer" type of thing. Its best to have someone or place that has done them install it right. Measurements with special tools need to be made to have the correct pinion/ring gear spacing or you will have premature wear which will result in a noisey rear end.
Old Oct 17, 2009 | 11:13 AM
scapegoat's Avatar
scapegoat
fair enough. i'll take it to a shop then. thanks
Old Oct 17, 2009 | 11:41 PM
brunobluto's Avatar
brunobluto
You can do it in your garage, but it is difficult. I've done it twice, you will need lots of tools, time and elbow grease. Without a lift you will have to remove the axle. Its not really hard , just unbolt a few things. Once out, you can remove the old gears. Installing the new gears is a very precise process. you will need various measuring devices, a hydraulic press makes pressing on a new pinion bearing easy. You know, i think i spent well over 700.00 to get all the special tools to install my gears. So unless you plan on changing them out again, just pay someone else to do it.
Old Oct 18, 2009 | 10:53 AM
JOHNNY's Avatar
JOHNNY
If you never done this before it's not a job to learn on it can be done but have someone that knows how to do it on call just in case. Yes you need some special tools and a touch for gear mesh?? good luck.
Old Oct 19, 2009 | 07:13 PM
scapegoat's Avatar
scapegoat
yeah, doesn't sound like something i want to get into then haha. i'm already going to be spending money on the gears and a tuner to fix the speedometer, another $700 in tools i won't use more than once or twice on this car isn't in the books.
i appreciate the responses. as much as i love to handle my own ****, this looks like a job for superman
Thunderball
15
Nov 22, 2015 11:49 PM
Bokeo
Oct 10, 2015 08:28 PM
KingRando
Oct 2, 2015 08:06 AM
uedlose
The Racers Bench
Oct 1, 2015 08:31 PM
junior04
Sep 28, 2015 10:53 AM
