Help w/ factory HID system
Gentlemen, here is the help i need
My friend is letting me switch out his factory HIDs from his 2008 C/S GT to my 2007 GT without HIDs
What is it that we need to do to switch these out successfully. I know that we will be switching the headlight assy, ballast, but I also know that there is normally a relay that is needed as well. Can anyone provide an assist ASAP. We will be doing this tomorrow. I believe the bumper cover has to be removed.
Thanks everyone for the help!
PASCAL, I may call you for some pointers!
thank you
jose
thank you
jose
All you need is the headlights and the wiring harness that connects to them. The ballasts are built into the headlight housings and the wiring harness has the relays. Here are the directions I used when I put the oem HIDs on my car http://www.steeda.com/directions/162...steeda_hid.pdf
Im not sure why they tell you to use diodes in that link. You absolutely do not need anything other than the factory harness with the relays and fuses. Ive had the factory HIDs in my car for 1 1/2 years and it works great
Here is my question.
His factory 2008 should have the harness as well correct? When I called Ford, they told me it was a $60 part that they did not have in stock, but would appear that it should already be in his car.
What I'm doing is switching them out, he is getting the lights from my 2007, and I'm getting his HIDs from his 2008. His car should have everything I need, so I think?
opinions?
opinions?
bradleyb
11-27-2015 07:50 PM
breaking
10-02-2015 01:27 PM
AMAlexLazarus
AmericanMuscle.com
10-01-2015 09:21 AM
