Static Noise on Shaker 500
Old Nov 4, 2009 | 01:50 PM
tutone56's Avatar
tutone56
Default Static Noise on Shaker 500
I know this thread was started a while back but I couldn't find it. I have the infamous noise coming from my Shaker 500 system as do many others. I went to the dealer today for the first oil change and mentioned the noise issue to them. Apparently I'm the first one to complain to them and they said there is no TSB that they are aware of. They concluded that since a few other new mustangs on the lot have the same noise that it is normal and therefore they said "no problems found". I'm not surprised by their answer.
Anyone have anything new addressing this issue?
Old Nov 4, 2009 | 02:27 PM
Adam's Avatar
Adam
Here are the threads:
https://mustangforums.com/forum/2010...dio-noise.html
http://forums.themustangsource.com/s...d.php?t=476692
Unfortunately I'm not aware of a TSB. Local Ford dealer wanted to reprogram my ACM but they never called back when I wanted more details.
Old Nov 4, 2009 | 03:08 PM
WeinerDog's Avatar
WeinerDog
One of my weiner dogs can hear it. I noticed yesterday when I was sitting in a parking lot with the engine off, I hit the Sync button to call someone and the noise came on, he cocked his head as dogs will do.
Maybe I should take him with me to the dealer and threaten to let him attack their ankles unless they fix it.
Old Nov 4, 2009 | 04:08 PM
Adam's Avatar
Adam
Your wiener is going to attack them? Woahhh way too much info
Old Nov 4, 2009 | 10:17 PM
chronos's Avatar
chronos
There is a TSB for the 05-09 model, but that may not apply to the 2010. Remember that TSBs are VIN specific and if they say it doesn't apply to your car, they wont do it. If I remember correctly, when I read the TSB it instructed the tech to swap the connections between the two amps to see if the noise persisted. If it did, then it was an amp problem. If not then it was something else, can't remember the second part. You could do the amp swap yourself and see if that narrows it down so you have something specific to complain about.
Old Nov 5, 2009 | 11:18 AM
m1215's Avatar
m1215
i have this problem on a 2009 and had it looked at twice. dealer said they cant hear the sound. i still cant find a tsb on it.
Old Nov 5, 2009 | 11:48 AM
10GTSTANG's Avatar
10GTSTANG
Man, that's nothing! I took my weiner dog to a nude beach one time, and he cocked his head too! He wanted to attack, but I stoped him!
Old Nov 6, 2009 | 06:43 AM
WeinerDog's Avatar
WeinerDog
Hope you didn't have to put a "choke hold" on him...
Old Nov 8, 2009 | 09:43 AM
tomz's Avatar
tomz
This thread seems to be going to the dogs. Back over at the thread I started July 19th on this shaker noise issue, I have changed the original post and most recent post requesting action.... So.... SPEAK! <g> (But SPEAK OVER THERE!)
https://mustangforums.com/forum/2010-...dio-noise.html
AJ_68 - do you have a posting rights on the other thread you listed?
Perhaps we can get orgainized in one thread.
Thanks,
Tomz
Old Nov 8, 2009 | 04:13 PM
chronos's Avatar
chronos
Way too much dicking around over here, that's for sure. Did you guys try the cable swapping I suggested? See if that helps any and you will know where to go from there.
bjdutch2005
Mar 24, 2017 03:38 AM
KingRando
Oct 2, 2015 08:06 AM
nmra1965
Other Professional Racing
Sep 26, 2015 10:46 AM
04stangman
Sep 17, 2015 01:45 PM
