Adjusting windshield washer fluid nozzles + paint harm?
Is it possible to adjust the wiper fluid nozzles? I had mine cleaned and now they spray up too high and onto the roof.
Will windshield wiper fluid harm the car's paint? Or convertible roof material?
Thanks!!
Thanks!!
Ok, I havent had my stock hood with sprayers on it for over a year now so I cant be for sure about how to 'aim' your sprayer nozzels. But I do know how I do it on my daily driver. Get a safty pin and poke the sharp end into the nozzle sprayer hole, then use the pin to move the sprayer around till you think you might be at a better spot. Take the pin out and test it. If its good, your done. If not, put the pin back into the sprayer hole and move it around where you think it needs to go.
Again, I cant verify this is correct since I cant go outside and check on mine, but that is most defintely how it works on my durango.
Hope this might help.
Andretti
Andretti
jwog666
12-27-2021 08:09 PM
09-25-2015 06:42 PM
