Cold Mornings
Old Nov 23, 2009 | 02:20 PM
gnrpatience's Avatar
gnrpatience
Originally Posted by Nuke
The dealer or any good shop can load test both the battery and the alternator. If you're experiencing hard starts due to slow cranking, then I'd start there. Otherwise and probably much less likely, you have a bad cable or you're starter has a few shorted windings causing it to pull more current when you crank.
I will take it to delearship and see if i can get battery and alternator tests. Also this is heppening when the car sits for more than 2 days.
Thanks
Old Nov 24, 2009 | 09:47 AM
bluovalguy's Avatar
bluovalguy
I am gonna agree with the battery. Do you know why your last one died? A two year old battery should not die, especially if temps as high as yours. So even though you have a new battery, maybe you have something drawing power and draining it.
Old Nov 24, 2009 | 11:09 AM
chain1's Avatar
chain1
I just noticed the same problem this year. When I start the car in the cold and it's been sitting for a few days, it cranks VERY slowly as though it's on its last legs. It eventually starts but I'm pretty sure if it gets any weaker I won't be able to turn it over enough to get it started. My battery (and car) are 2.5 years old.
Old Dec 4, 2009 | 10:46 AM
gnrpatience
I have a question, if it is the battery or alternator, why is not happening always and also If i start my car and I have the cranking issue then i take it out of garage turn it off then start it up and it will come up quickly as normal ?
Old Dec 4, 2009 | 04:17 PM
WYO07GT's Avatar
WYO07GT
It was about -5 F yesterday morning when i started mine, the first crank was a touch slower and it usually takes a few extra cranks to catch, but nothin crazy.
Old Dec 4, 2009 | 04:47 PM
silverstang23's Avatar
silverstang23
personally the colder the weather get the better my stang runs
Old Dec 4, 2009 | 05:01 PM
gnrpatience
I think same here, but i mean when starting it onthe morning or after 2 days of sitting it will be lazy but o nthe road it iwll kick ***.
I just confused why if it could be the alternator it is not happening always no matter if it is in the morning, evening, etc..
4cylinderplus2
Oct 9, 2020 07:45 PM
lincolnshibuya
Dec 8, 2015 04:37 PM
Dokilar
15
Oct 16, 2015 08:13 PM
ChampInSD
Oct 2, 2015 04:55 AM
