TPMS problems
Old Dec 13, 2009 | 01:45 PM
cegha's Avatar
cegha
Default TPMS problems
Hey guys i've had aftermarket rims with 4 new TPMS sensors on my car since march 09. Just last night as I was pulling into my driveway i got a "low tire pressure" message.
I went this morning outside & checked all the tire pressures, & they said 28-29PSI in each. Which is where they should be I believe. I think there 275/45/18. Yet the light is still on in my car. I don't know how to tell if there is a problem with the sensors or which sensor it would be.
Would they somehow mabye need to be reset. My car still has a warranty but I don't think dealership will look at TPMS sensors since there on aftermarket rims.
Also I have a problem with my door handle sticking as well within the last week. Passanger door handle, you know how it pulls outwards a little bit, well it's not retracting all the way back when in the normal position. Any advice on that.
Old Dec 13, 2009 | 02:09 PM
Nuke's Avatar
Nuke
Check the spare tire pressure. Colder weather will reduce tire pressure by roughly 1 PSI for every 10 degree F ambient change. Also, if your gauge is reading a little on the high side you may very well have a tire or 2 at or below the set-point of the sensors (which I believe is 27 PSI). I suggest you consider running your tires a little higher but it really depends on what you prefer handling and ride wise. Every new tire I put on the car, I usually adjust the pressure by 2 PSI increments until I find what suits me. I usually end up between 31 and 36 PSI, depending on the tire.
Old Dec 13, 2009 | 08:49 PM
SkyWitit23's Avatar
SkyWitit23
same here I have the 7 spoke saleens and my light came on yesterday, i have the nitrogen, but anywho i went to the dealer just to refill each tire and the light came off , your tires must be off still for the light to go on..Im glad i bought the Sensors just in case of this problem...
Old Dec 13, 2009 | 09:18 PM
Acerbus 2.0's Avatar
Acerbus 2.0
I didn't know spares also had TPMS. Thanks.
OP
I've had the TPMS light come up twice already. When I checked the PSI it was also between 26-28PSI all around. Filled them to 32PSI as according to the door sticker and the light went away after a mile of driving or so.
Seems the TPMS on these cars wants to see the PSI over 30 or so, or else it goes haywire.
Old Dec 14, 2009 | 09:36 AM
cegha's Avatar
cegha
Thanks for help guys. I will fill them up to like 30-32PSI & see what happens. Also I don't have a spare in my car. My spare hasn't been in my car for some months now.
Old Feb 1, 2011 | 06:24 PM
TinPony's Avatar
TinPony
Default TPMS
Low pressure warning came on and after adding air (33.5 lbs) in each tire and 45 in the spare, I cant get to light to go out.... anyone have a suggestion?
Old Feb 1, 2011 | 08:08 PM
redvertstang's Avatar
redvertstang
Try resetting the system.
Old Feb 1, 2011 | 08:30 PM
blackgtstang's Avatar
blackgtstang
I dont think the spares have a sensor and also 28 psi is a little low..
Old Feb 1, 2011 | 08:35 PM
aaquib1992's Avatar
aaquib1992
I think nuke was joking guys. Lol.
Anyway, I had the light for a little while and then it went away. Was kinda weird, but I think its the temp thing. I say set it to the specified amount and leave it. But then, here in Indy we have erratic temp changes every day.
Old Feb 1, 2011 | 10:38 PM
TinPony's Avatar
TinPony
Amazing... after 20 minutes of driving it finally went off..... and yes the spare does have one...
Seanam
Oct 4, 2015 10:15 AM
mdj89
Sep 23, 2015 08:49 AM
kachuy10
Sep 22, 2015 01:27 PM
stangin1996gt
Sep 21, 2015 11:01 AM
Big Al's 03
Mach 1 Section
Sep 21, 2015 07:59 AM
