Brakes...
Those option descriptions only say upgrade brake PADS... Not calipers or rotors. The GT500 of course has a better braking system.
It's possible that maybe they offer a packer for the sixxer tha upgrades to a GT braking system, but I don't know about that. I have never looked into buying a '10, let alone a '10 sixxer.
Get some decent rotors. I got powerslots. Nothing crazy.
Get some Hawk HPS pads.
The new pads do not out gas like the OEM pads and can take heat better. I have not had brake fade since I changed my pads and rotors.
No, just keep the tire size close to the same diameter as the stock then you don't have to worry about speedo recal...
Also when making your wheel selection decide if you are EVER going to want a big brake kit. Cause not all will allow the use of one...
Ok so this is what is on there I guess is this same as a 05 to 09
Brakes, front 12.4-by-1.18-inch ventilated discs with 2-piston floating calipers
Brakes, rear 11.8-by-0.75-inch ventilated discs with single-piston floating calipers
