How big of a difference does Gas make?
all right, thanks guys.
the purpose of the thread was not why he pulled from me but the difference in octane rating. i know ill have the faster car once i start my modding
i don't think the 6 speed tranny has much to do with anything. the only advantages the 370z has on the stang is 200 lbs and 17 hp. which is easily made up for with my extra 50 ft-lb of TQ.
your driving habits are why he's pulling on you. you're doing your motor a disservice by shifting below 4k. the motors are broken in from the factory for one... and two, when you break in a motor you do so at various RPM's. by keeping it under 4k, in theory, your car will not perform as well across the RPM range.
there is a lot of debate regarding break in. many suggest a hard break in... ie: drive it like you normally would. this helps every wear in at the expected use.
further, i wasn't aware that on the stock factory computer tunes that 87 and 91+ tunes would result in the same performance. something tells me (common sense) that that would be incorrect.
^^^ thats one of the reviews i was referencing, the two cars are almost identical when it comes to performance.
i would rather not get into the breaking in debate, i am using the technique that my dad taught me. as i said in my original post it was a half-hearted race i never went above 55(in a 45) as i think street racing is wrong.
scapegoat are you saying that there should be a hp difference between the two octane ratings? while small i think there is maybe a 10hp ish difference
while i'm not a mechanic in any way shape or form, a higher octane is going to give you a "bigger bang"... its going to perform better than 87 octane.
I would have assumed that a 93 tune from the factory is going to run more aggressively than its 87 factory tune. it just doesn't make sense to me that both tunes would result in 315bhp.
I did a 87 tune due to not wanting to run the higher cost 93, but if I run 93 on my 87 tune runs great, with the jlt the size of the thing going from 85 mm (stock) to 110mm I had to get a custom tune so did 87, 315 hp on the 2010 as we know is fly wheel that no one goes by but Ford to intice us, like the 2011 which say over 400 hp but is going to be more like 380, just like mine rated at 315, was 282, but after 87 tune here is my dyno sheet, with a 93 it would go over 300, hope helps or just good info
from the manual,,,,,,,,,,
Octane recommendations (4.6L V8 engine)
Your vehicle will run normally on 87 octane regular fuel without
damaging the engine, but premium fuel with an octane rating of 91
(R+M)/2 or higher is recommended for best overall performance.
