Modification Questions
Old Jan 25, 2010 | 08:35 PM
Cusp's Avatar
Cusp
Originally Posted by rneely2111
Should I get this also? Posi-Trac (Clutch-Style) Rear Axle Differential
Mustang with 8.8 rear axle
you already have fords version of Posi-track. Trac-Lok. Their limited slip axle. So no need.
Old Jan 25, 2010 | 09:03 PM
Commander Bubbles's Avatar
Commander Bubbles
Depends what you use your car for. If you race a bit, use it for weekends, and aren't adding FI, then get 4.10's...otherwise 3.73's or 3.90's (if available for these, idk). The latter is a good upgrade anyway. It just depends if you need extra pull.
I hear MGW makes good shifters for S197's.
Good luck.
You should take the big front pic out of your sig too- there are "size limits", fyi.
Old Feb 7, 2010 | 10:27 PM
CaliStang13's Avatar
CaliStang13
what do you guys think is the best short throw shifter? looking to buy one within the next couple of weeks. the ones i have in mind is the hurst one or shelby. Help my plz.
Old Feb 7, 2010 | 10:35 PM
10GTSTANG's Avatar
10GTSTANG
How about a Detroit locker with 4.11s and 31 spline axles?
Old Feb 8, 2010 | 09:31 PM
notsofast's Avatar
notsofast
Originally Posted by Cusp
Many forum people will say 4.10 for the win. But I suspect they are 20 somethings with extreme tendencies. .
I am 51 and I have 4.10s and an MGW shifter. The 4.10s really wake up the drivetrain - makes 4th gear relevant again. It's my DD. The MGW has made it a little louder, but now I am addicted to the noise. Maybe I do have extreme tendencies. If I had to do it again - 4.10's without a doubt.
Old Feb 9, 2010 | 11:21 AM
gman73's Avatar
gman73
I also went with 4.10s. My 06 came with 3.55, so 3.73 wouldn't have been worth it. My car is my DD and I drive about 65 miles per.day with 90% of the miles being on the hwy.
Old Feb 9, 2010 | 12:23 PM
distantsoldier's Avatar
distantsoldier
I have 3.73 in my GT500 with an even shorter throw shifter than stock...and most of the time I wish I have more acceleration than I have now. But I'm insane. I would step up to 4.10 if I could...but even with Nitt0 555R Extremes in a 305 I can still blow em off...so 4.10s would just be worse.
Dokilar
15
Oct 16, 2015 08:13 PM
AMAlexLazarus
AmericanMuscle.com
Oct 2, 2015 08:06 AM
AMAlexLazarus
AmericanMuscle.com
Oct 1, 2015 10:29 AM
AMAlexLazarus
AmericanMuscle.com
Oct 1, 2015 09:21 AM
treesloth
Sep 28, 2015 07:03 AM
